EM7455 "System mode: Unknown" Issue
How do I recover the EM7455 modem from “Unknown” system mode state.
AT!GSTATUS?
!GSTATUS:
Current Time: 14401 Temperature: 39
Reset Counter: 2 Mode: ONLINE
System mode: Unknown PS state: Not attached
AT+COPS?
+COPS: 0
AT+COPS=?
ERROR
AT+COPS=?
+CME ERROR: operation not allowed
AT!GETBAND?
!GETBAND: No Service
AT!PCINFO?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
LPM persistence - None
ATI
Model: EM7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: A000005368D949
ESN: 12807986565, 8079DD85
IMEI: 359073065280905
IMEI SV: 12
FSN: LF942404500210
+GCAP: +CGSM
AT!GCDUMP
No crash data available
AT!IMAGE?
FW 1 GOOD 22 0 0 ?? 02.24.05.06?
FW 2 GOOD 17 0 0 ?? 02.24.03.00?
FW 3 GOOD 21 0 0 ?? 02.33.03.00?
FW 4 GOOD 19 0 0 ?? 02.32.11.00?
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.027_000 02.24.05.06_ATT
PRI FF GOOD 0 0 0 002.026_000 02.24.05.06_GENERIC
PRI FF GOOD 0 0 0 002.022_000 02.24.03.00_SPRINT
PRI FF GOOD 0 0 0 001.000_000 00.00.00.00_OEMPRI918
PRI FF GOOD 0 0 0 002.034_000 02.24.05.06_VERIZON
Max PRI images: 50
AT!IMPREF?
!IMPREF:
preferred fw version: 02.24.05.06
preferred carrier name: VERIZON
preferred config name: VERIZON_002.034_000
current fw version: 02.24.05.06
current carrier name: VERIZON
current config name: VERIZON_002.034_000
AT!PRIID?
PRI Part Number: 9907469
Revision: 001.000
Customer: Generic-M2M
Carrier PRI: 9999999_9904594_SWI9X30C_02.24.05.06_00_ATT_002.027_000
Carrier PRI: 9999999_9904609_SWI9X30C_02.24.05.06_00_GENERIC_002.026_000
Carrier PRI: 9999999_9904779_SWI9X30C_02.24.03.00_00_SPRINT_002.022_000
Carrier PRI: INTERNAL_9901234_EM7455_00.00.00.00_00_OEMPRI918_001.000_000
Carrier PRI: 9999999_9904780_SWI9X30C_02.24.05.06_00_VERIZON_002.034_000
AT!BAND?
Index, Name, GW Band Mask L Band Mask TDS Band Mask
09, LTE ALL, 0000000000000000 000000000000101A 0000000000000000
Hi @akn
You are not in the latest firmware, please download the latest firmware(SWI9X30C_02.33.03.00) and retry.
You can get it at here:
https://source.sierrawireless.com/resources/airprime/minicard/74xx/airprime-em_mc74xx-approved-fw-packages/#sthash.FTfL7zc0.dpbs
If it still cannot register to the network, please share me the log file with the following commands.
AT!ENTERCND="A710"
AT!BAND?
AT+CGDCONT?
AT!GSTATUS?
AT!IMPREF?
Registration is still failing even with the latest Verizon firmware.
How do I recover from this state without rebooting my host device?
AT!ENTERCND="A710"
AT!BAND?
AT+CGDCONT?
+CGDCONT: 1,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 2,"IP","vzadmin","0.0.0.0",0,0,0,0
+CGDCONT: 3,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 4,"IPV4V6","vzwapp","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 5,"IPV4V6","vzw800","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 6,"IPV4V6","vzwclass6","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
AT!GSTATUS?
!GSTATUS:
Current Time:  256              Temperature: 39
Reset Counter: 6                Mode:        ONLINE
System mode:   LTE              PS state:    Not attached
LTE band:      B4               LTE bw:      20 MHz
LTE Rx chan:   2300             LTE Tx chan: 4294967295
LTE CA state:  NOT ASSIGNED
EMM state:     Deregistered     Limited Service
RRC state:     RRC Idle
IMS reg state: No Srv           IMS mode:    Normal
PCC RxM RSSI:  -78              RSRP (dBm):  -120
PCC RxD RSSI:  -78              RSRP (dBm):  -121
Tx Power:      --               TAC:         3174 (12660)
RSRQ (dB):     -20.0            Cell ID:     0140680A (20998154)
SINR (dB):     -8.6
AT!IMPREF?
!IMPREF:
 preferred fw version:    02.33.03.00
 preferred config name:   VERIZON_002.079_001
 preferred subpri index:  000
 current fw version:      02.33.03.00
 current config name:     VERIZON_002.079_001
 current subpri index:    000
Hi @akn
I see your EM7455 registered network successfully on previous tickets.
https://forum.sierrawireless.com/t/automatic-rrc-connection-request/20071/5
Do you use the same Verizon SIM?
I am using 2 SIMs. One with dynamic and one with static IP.
“System mode: Unknown” issue was seen with both of these SIMs.
I was unable to resolve even after modem reset.
Registration was successful only after host system reboot.
Please ignore RRC related query as it was seen on different setup and now I don’t have access to it.
Hi @akn
The issue is solved. Please help to tick “Solution”.
Yes, rebooting the host system resolved this issue.
Can I avoid host system reboot and recover from this error?
Hi @akn,
The host system may have a problem, so you need to restart it.
