I have a bunch of EM7455 modems, all of them are updated to latest fw for now, and I have a problem that modems sometimes starts to reboot every ~2 minutes, here is the info from one of them:
at!image?
FW 1 GOOD 1 0 0 ?? 02.39.00.00?
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.085_000 02.39.00.00_GENERIC
Max PRI images: 50
at!priid?
PRI Part Number: 9904609
Revision: 002.085
Customer: Generic-Laptop
Carrier PRI: 9999999_9904609_SWI9X30C_02.39.00.00_00_GENERIC_002.085_000
at!gstatus?
!GSTATUS:
Current Time: 53 Temperature: 42
Reset Counter: 13 Mode: ONLINE
LTE band: B3 LTE bw: 10 MHz
LTE Rx chan: 1596 LTE Tx chan: 19596
LTE CA state: NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -79 RSRP (dBm): -111
PCC RxD RSSI: -77 RSRP (dBm): -111
Tx Power: -- TAC: 1EAD (7853)
RSRQ (dB): -14.6 Cell ID: 0BE73EC8 (199704264)
SINR (dB): -2.0
at!gcdump
Src: FatalError
File: ostime_modem.c
Line: 204
Str: SWI_ABORT-M: timer already running
0000EA60 00000000 00000000 00000000
Prc: MPSS
Task: DCC
Time: 0001E1FA
R0: EC902000 R1: 9E8A2B1D R2: 9B0B2477 R3: 01112A86 R4: 00009B0B
R5: 00000000 R6: 0000002A R7: 00000000 R8: 01112A86 R9: 00000000
R10: 00000011 R11: 15FEEDA5 R12: 00000111 R13: 00000000 R14: 00000001
R15: 00000000 R16: 00000000 R17: 00000000 R18: 0000EA60 R19: 0552F440
R20: 04FA8E40 R21: 9F2A2108 R22: 044A14E0 R23: 0205D3EC R24: 00000000
R25: 00000000 R26: 00000000 R27: 00000000 R28: 00000001 SP: 9F2A2080
FP: 9F2A2088 LR: 0212E370
PC: 02054610
CPSR: 00000000
Mod: Unknown
TOS
9F2A20A8 0212E3C0 044A14E0 9F2A2108 7FFFFFFE 0366C228 00000000
FC759350 9F2A20B0 02054610 9F2A2100 0205DAF8 02AE0C70 7FFFFFFE
9F2A20F8 021A3294 04B2DE40 0205D3EC 7FFFFFFE 00000000 04B2DE40
0205D3EC 04B2DE40 0205D3EC 04B1FAC8 00000000 00000000 04B2DE40
FC759350 0000000A 9F2A21F0 0205D4B8
BOS
App ver: SWI9X30C_02.39.00.00
at!err
QDSP6 ARM9 (not saved)
00 01 seccrypt 00209
01 01 gpstask 04204
02 01 stm 00515
03 01 hdrscmdb 05334
04 01 rdevmap 01604
05 01 gsnvif 00855
06 01 hdridle 00819
07 01 sys_eplm 00691
08 01 mc_recei 02346
at!pcvolt?
Volt state: Normal
Power supply voltage: 3675 mV (ADC: 37094)
Sometimes it can reboot like that for 30 times or more, and sometimes it does not reboot. I tried changing some settings and flags, but no result. Also tried to flash various fw versions from SWI9X30C_02.39.00.00 to SWI9X30C_02.30.01.01, and no result indeed. I found out that if I put modem in LPM mode with AT+CFUN=0, them modem stops rebooting. If I put it back in normal mode, them it starts rebooting again.
Can anyone help with that? I know that EM7455 is EOL, but I have about 30 of them, and I just don’t really want to throw them out.
