EM7455: How do I enforce CA mode?
Currently I checking it with AT!GSTATUS. But there is no way to control it.
!GSTATUS:
Current Time: 3482 Temperature: 37
Reset Counter: 2 Mode: ONLINE
LTE band: B4 LTE bw: 20 MHz
LTE Rx chan: 2100 LTE Tx chan: 20100
LTE CA state: NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: Limited IMS mode: Normal
PCC RxM RSSI: -59 RSRP (dBm): -92
PCC RxD RSSI: -63 RSRP (dBm): -95
Tx Power: – TAC: 2F05 (12037)
RSRQ (dB): -12.7 Cell ID: 054BF620 (88864288)
SINR (dB): 4.4
i don’t see there is a way to control it
Unfortunately, I don’t believe you can force it to use CA. You can restrict which bands it uses which I’ve found to be useful in a fixed-location scenario since in my case the card & particular tower supports CA with some channels but not others so I don’t want the card to accidentally move to one of the channels that can’t support CA.
