EM7455 firmware update to 2.20.03
I am using the latest Sierra SDK Sierra_04.00.02, and I am trying to update the firmware on EM7455 from 2.08.02 to 2.20.03, everything seems to go well (I get the success as result) but when I check the firmware in the modem, it is still the old 2.08.02.
I am running on iMX6 ARM platform, all related binaries seems to be working ok.
root@mserver115:/tmp# ls -la SWI*
-rw-r–r-- 1 root root 64381598 Oct 26 19:55 SWI9X30C_02.20.03.00.cwe
-rw-r–r-- 1 root root 3062 Oct 26 19:55 SWI9X30C_02.20.03.00_Generic_002.017_000.nvu
root@mserver115:/tmp# echo raw,‘AT!BOOTHOLD’ | nc localhost 8080
AT!BOOTHOLD
root@mserver115:/tmp# ./slqssdk &
[1] 611
root@mserver115:/tmp# ./fwdldarm -s /tmp/ -d 9x30 -p /tmp/ -k
Detecting USB of the target
DONE
Communicating with the target
DONE
Downloading the firmware
.DONE
Rebooting the module
…DONE
Firmware Download SUCCESS
[1]+ Killed ./slqssdk
root@mserver115:/tmp# echo raw,‘ATI’ | nc localhost 8080
ATI
Model: EM7455
Revision: SWI9X30C_02.08.02.00 r5428 CARMD-EV-FRMWR2 2016/01/06 20:38:53
MEID: 35432407003201
IMEI: 354324070032012
IMEI SV: 4
FSN: LF548120770310
+GCAP: +CGSM
When I check the update status in the modem, it will also indicate that all is well.
root@mserver115:/tmp# echo raw,‘AT!BCFWUPDATESTATUS’ | nc localhost 8080
AT!BCFWUPDATESTATUS
!BCFWUPDATESTATUS: SUCCESS
TYPE=SPKG,STATUS=PASS
I tried to boot the modem again, and there is no sign of the 2.20.03 firmware.
am I missing something?
Regards,
Sebastian
Is there any reason you issue the boothold command? This should not be nesessary. Are there any other files (particularily CWE or NVU files) in the /tmp folder?
No, but I had problem for fwdldarm to find the device, and it did work after I did put it in BOOT HOLD, but maybe I was just lucky. I can try without it.
Yes, the files are in the same directory, everything happens in /tmp and all files are there as well.
Regards,
Sebastian
Maybe ‘AT!IMAGE?’ and/or ‘AT!IMPREF?’ will explain the problem? I believe the normal EM/MC74xx firmware update procedure is to change IMPREF and then upload new PRI and MODEM images as required. That works for me at least.
Looks like that firmware was not flashed after downloading. I had EM7455 on Windows 10 Pro 64 bit environment and just recent updating with latest same firmware release where with a successful result. I believe “boot and hold” mode shall be taken care by that script itself.
Regards,
That is interesting, those commands I can not find in the AT command document. I can see that it has installed the PRI file.
I wonder if I could specify a specific slot where the new firmware should go to?
at!image?
FW 1 GOOD 1 0 0 ?? 02.08.02.00?
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.017_000 02.20.03.00_GENERIC
Max PRI images: 50
at!impref?
!IMPREF:
preferred fw version: 02.08.02.00
preferred config name: GENERIC_002.007_000
current fw version: 02.08.02.00
current carrier name: GENERIC
current config name: GENERIC_002.007_000
Regards,
Sebastian
Without the BOOTHOLD the fwdldarm cannot find the device. But it seems that now the update is failing on error.
root@mserver115:/tmp# ./fwdldarm -s ./slqssdk -d 9x30 -p /tmp/
No device connected
No device connected
No device connected
No device connected
AT!BOOTHOLD
DONE
DONE
…ERROR: Firmware Download failed. Callback status 59399DONE
ERROR: Firmware Download Failed
And I guess it did not come that far, as I don’t see any signs here;
AT!BCFWUPDATESTATUS
root@mserver115:/tmp# echo raw,‘at!image?’ | nc localhost 8080
at!image?
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Max PRI images: 50
root@mserver115:/tmp# echo raw,‘at!impref?’ | nc localhost 8080
at!impref?
!IMPREF:
-Sebastian
I have the same trouble, and I have been resolved it not long ago.
I found a suggestion, and I tried to remove modemanager.
Finally the firmware upgrade was finished with QMI SDK.
BRs,
Allen
Thank you for the reply, but I don’t have modem manager installed at all. I do have libqmi, but there is no active process running that would be related to the device.
However, after the first failure something must be wrong now, because now it fails with a callback status code.
DONE
DONE
-Sebastian
