EM7455 can't connect to T-Mobile (+CME ERROR: no network service)
I have a rebranded (Dell) EM7455 that works great on AT&T but I can’t get it to connect to T-Mobile. When I try AT!SCACT=1,1 it returns +CME ERROR: no network service
I know my SIM is active because I can put it in a microtik router and everything works fine.
What I have tried:
1a. Flashing the modem with the Generic firmware package:
sudo qmi-firmware-update -t /dev/ttyUSB0 --update-qdl SWI9X30C_02.33.03.00.cwe SWI9X30C_02.33.03.00_GENERIC_002.072_000.nvu
1b. AT command results:
at!entercnd="A710"
at!priid="9904609","002.072","GENERIC"
at!priid?
PRI Part Number: 9904609
Revision: 002.072
Customer: GENERIC
Carrier PRI: 9999999_9904609_SWI9X30C_02.33.03.00_00_GENERIC_002.072_000
Carrier PRI: 9999999_9904594_SWI9X30C_02.32.11.00_00_ATT_002.070_002
Carrier PRI: 9999999_9904780_SWI9X30C_02.33.03.00_00_VERIZON_002.079_001
at!gobiimpref?
!GOBIIMPREF:
preferred fw version:    02.33.03.00
preferred carrier name:  GENERIC
preferred config name:   GENERIC_002.072_000
preferred subpri index:  000
current fw version:      02.33.03.00
current carrier name:    GENERIC
current config name:     GENERIC_002.072_000
current subpri index:    000
at!gstatus?
!GSTATUS:
Current Time:  168              Temperature: 27
Reset Counter: 12               Mode:        ONLINE
System mode:   LTE              PS state:    Attached
LTE band:      B4               LTE bw:      20 MHz
LTE Rx chan:   2300             LTE Tx chan: 20300
LTE CA state:  NOT ASSIGNED
EMM state:     Registered       Normal Service
RRC state:     RRC Idle
IMS reg state: No Srv
PCC RxM RSSI:  -88              RSRP (dBm):  -118
PCC RxD RSSI:  -89              RSRP (dBm):  -122
Tx Power:      --               TAC:         352C (13612)
RSRQ (dB):     -10.6            Cell ID:     01713302 (24195842)
SINR (dB):      6.6
at+creg?
+CREG: 0,1
+CGREG: 0,1
at+cereg?
+CEREG: 0,1
at!scact=1,1
2a. Flashing the modem with the TMO (Generic) firmware package:
sudo qmicli -d /dev/cdc-wdm0 -p --dms-set-firmware-preference="02.30.01.01,002.045_001,GENERIC"
sudo qmi-firmware-update -t /dev/ttyUSB0 --update-qdl SWI9X30C_02.30.01.01.cwe SWI9X30C_02.30.01.01_GENERIC_002.045_001.nvu
This particular package didn’t bring up /dev/ttyUSB2 until I did the following command as well
sudo qmicli -d /dev/cdc-wdm0 -p --dms-swi-set-usb-composition=6
2b. AT command results:
at!entercnd="A710"
at!priid="9904609","002.045","GENERIC"
at!gstatus?
!GSTATUS:
Current Time:  1052             Temperature: 26
Reset Counter: 11               Mode:        ONLINE
RRC state:     RRC Idle
PCC RxM RSSI:  -87              RSRP (dBm):  -120
PCC RxD RSSI:  -90              RSRP (dBm):  -123
RSRQ (dB):     -12.9            Cell ID:     01713302 (24195842)
SINR (dB):      4.0
at!impref?
!IMPREF:
preferred fw version:    02.30.01.01
preferred config name:   GENERIC_002.045_001
current fw version:      02.30.01.01
current config name:     GENERIC_002.045_001
at+creg?
+CREG: 0,1
at+cgreg?
+CGREG: 0,1
at+cereg?
+CEREG: 0,1
at+cops?
+cops: 0,0,"T-Mobile",7
at!scact=1,1
Any ideas? My modem with an AT&T SIM card works great (using the ATT package).
I tried on a non-rebranded EM7455 from Digikey, same issue.
Hi @ww1 ,
The log shows the module is able to attach T-Mobile network successfully. Data connection just is activated when the module should be set APN corresponds to TMobile’s. Please share the response of PDP context configuration by the command below
AT+CGDCONT?
Thanks for getting back to me so quickly!
I thought it might be an APN issue, I tried “fast.t-mobile.com” with IP, IPV4V6, and IPV6 for good measure. I also tried “epc.t-mobile.com”
at+cgdcont?
+CGDCONT: 1,"IPV4V6","fast.t-mobile.com","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
I will call T-mobile today and see if it is a problem on their end, but it sounds like there aren’t any red flags from the modem itself which is good to hear.
Called tech support. The T-Mobile “unlimited data” plans are cell phone only and can’t be used with WWAN modems
Tried 3 different plans, none of them worked. I wonder if T-Mobile just has the EM7455 blacklisted or something. I’ll post if I actually get it working, but at this point I might just stick with AT&T.
Hi ww1
Did you ever get your em7455 to work with T-Mobil?
Trying to do the same,no luck.
Yes! Most of my issues went away when I enabled “AUTO-SIM”
Try the following command:
!IMPREF=“AUTO-SIM”
It should cause the modem to reset to the right firmware
Edit: Actually no, I misremembered. Pretty sure T-Mobile never worked, we swapped to AT&T
