Here is my problem, i have a EM7455 Generic Sierra Module with the latest firmware running, connected through an USB M.2 adapter, after a lot of struggle I managed to make it work on Windows 10 and I can now access every functionnality. My goal is to use the module on an Android device that DOES NOT have native 3G/Lte support.
Now how can I install MBPL R32 Drivers to a rooted Android device ? I have downloaded every driver looking for information but it is pretty confusing to me as there is no step-by-step or general information about these Drivers as they are pretty recent.
Thanks for any information.
Android Specs :
Version : Android 10
Processor : RK3399
Kernel Version : 4.4.167+
Thanks for the insight, I thought that MBPL was supposed to replace Android RIL, so there is no Sierra Wireless driver for Android then ? Do you mean the distributor of the EM7455 module or the distributor of the Android OS ?
Every link I found on Sierra website leading to Android RIL returns 404 error infortunatly.
I can’t find the paths you specified on my android device and the readme.txt provided with qcserial.c and qmi_wwan.c states that I have to generate the drivers binary but no specific information is provided :
Sierra Wireless USB Drivers
Supported Product Families (based on chipset): SDX65, SDX55, 9x50, 9x30, 9x15, 9x07
How to Build the driver
run "make" to generate the driver binaries: qcserial.ko, usb_wwan.ko and qmi_wwan.ko
How to Install the driver
1. run "make install"
2. reboot
Note: Linux kernel may not load driver if secure boot is enabled in BIOS.
Secure boot need to be disabled in BIOS and reboot.
I bought my module on amazon like 90% of the people on this forum so I messaged the reseller but I don’t expect anything much.
I checked on Android Studio on an emulated Android 10 device provided by Google and the “common” folder does not appear either in the device root folder.
This post doesn’t explain where the files are located and how to enable the drivers :
I can enable option and usbserial drivers at /sys/bus/usb/drivers; however, how to enable qmi_wwan at /sys/bus/usb/drivers?
I don’t have any option or usbserial inside /sys/bus/usb/drivers
Again here is the content of the folder :
I added the following at the file: imx8mq_ima_gki.fragment
And I added the following at the file: imx_v8_ima_android_defconfig
And I added the following at the file: SharedBoardConfig.mk
Where are those files supposed to be ?
Sorry for my lack of understanding
