EM7421 - "AT+CPID?" Error
We are having a problem with Sierra EM7421 modem.
Trying to commands on EM7421 we get the following:
EM7421
On the other hand, we tested Sierra EM9191 on our platform and it works fine. (we are able to connect to internet):
Here is a link to our M.2 Key-B Design.
What could be the problem?
NOTE: EM7421 FW : SWI9X50C_01.14.03.00 b06bd3 jenkins 2020/09/23 10:53:35
Best Regards,
Firas
You type the wrong command
+cpin , not cpid …
Sorry, I had a typo in my command: AT+CPIN?
the output is: +CPIN: Ready.
but still can’t click on Cellular and turn it ON. we can do this with EM9191 and browse the internet without any problem using same design and SIM.
Rami_Levi_Cant_Turn_ON_EM7421
what could be the problem?
Have you set apn?
Have you checked at!gstatus?
Have you checked signal state?
Have you enabled mbim interface?
Here are some commands that I have checked, bottom line, I still can’t browse the internet. is it something has to do with Windows configuration?
I tried also with E7411 without success!
I also tried to configure APN. it didn’t help.
the APN I enter is: “internet.rl”
in addition to user and password.
this is what I get:
AT
ati
Model: EM7411
Revision: SWI9X50C_01.14.03.00 b06bd3 jenkins 2020/09/23 10:53:35
IMEI: 356280110977707
IMEI SV: 13
FSN: 8F2041242803B1
+GCAP: +CGSM
at+cmee=1
at!priid?
PRI Part Number: 9909851
Revision: 002.008
Customer: Generic-M2M
Carrier PRI: 9999999_9907259_SWI9X50C_01.14.03.00_00_GENERIC_002.036_009
at!image?
FW 1 GOOD 2 0 0 ?? 01.14.03.00?
FW 2 GOOD 1 0 0 ?? 01.14.07.00?
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.048_006 01.14.03.00_ATT
PRI FF GOOD 0 0 0 002.036_009 01.14.03.00_GENERIC
PRI FF GOOD 0 0 0 002.005_003 01.14.03.00_TMO
PRI FF GOOD 0 0 0 002.045_005 01.14.07.00_VERIZON
Max PRI images: 50
at!gstatus?
!GSTATUS:
Current Time: 214 Temperature: 25
Reset Counter: 1 Mode: ONLINE
LTE band: B7 LTE bw: 20 MHz
LTE Rx chan: 3250 LTE Tx chan: 21250
LTE SCC1 state:NOT ASSIGNED
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -74 PCC RxM RSRP: -114
PCC RxD RSSI: -75 PCC RxD RSRP: -113
Tx Power: – TAC: 1d6b (7531)
RSRQ (dB): -18.0 Cell ID: 001b5e11 (1793553)
SINR (dB): 0.2
at+cpin?
+CPIN: READY
at+cimi
425030300880522
at!pcinfo?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, RFCAL:0
LPM persistence - None
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
SINGLEAPNSWITCH 0x01
QXDMLOGENABLE 0x01
at+creg?
+CREG: 0,1
at+cgreg?
+CGREG: 0,1
at+cereg?
+CEREG: 0,1
at+cgpadr=1
ERROR
at+cgpaddr=1
+CGPADDR: 1,10.79.8.145,42.2.102.128.17.7.45.226.145.38.234.133.172.11.178.86
at!selrat?
!SELRAT: 00, Automatic
at
ERROR
at+cg
ERROR
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at!uims?
!UIMS: 0
at!impref?
!IMPREF:
preferred fw version: 01.14.03.00
preferred config name: GENERIC_002.036_009
preferred subpri index: 000
current fw version: 01.14.03.00
current carrier name: GENERIC
current config name: GENERIC_002.036_009
current subpri index: 000
at!band?
Index, Name
00, All bands
I don’t see apn in +cgdcont
Strange that gstatus shows lte but windows shows umts
