Hello, I am new to the EM7355. I got it working in my Toughbook I can browse the internet and use SMS. My next question is there anyway to receive calls make calls with it… my plan allows for talk and data and I have a phone number associated with the SIM… but I can’t figure out how I would dial out or receive a phone call over 4G/3G network?
it has a GSM module ,so obviously can make voice calls, but you need a software for it. I still can’t find one. A good programming engineer can do it easy.
So in theory you can make a voice call with the unit but it will not route the voice data stream anywhere making it effectively not support voice given you cannot hear it or send it.
Hi - it’s an old thread but nice to see some interest. I found out I have VoLTE support on my network but still no go with these radio modems. I have been waiting to see if any of the newer radios from Sierra Wireless support voice as these ones seem to have depreciated.
Hi, I just bought a module for my thinkpad X240 and waiting for delivery. As the company behind the software mentioned before ,claims that it can make phone calls I will check it immediately. Actually there is nothing complicated to do it because GSM is a binary transmission and the device modulates your voice with PCM, after it all is just numbers.You can download the software AT command tester, it has 7 days trial. I will let you know if it works after couple of days. Here is a video of the AT command tester, you can see one of the options is DATA CALL which obviously is via GSM .https://www.youtube.com/watch?v=xiUlsqQ374c&t=26s
I seem to recall trying this software last year and while it could dial there was no way to transmit or receive audio. I soon gave up with that I think there is a software needed to route the audio.
Hi, I don’t understand what you mean by route the audio, but logically an analogue audio input ,as your voice ,is converted with an ADC chip to 1and 0 ,actually coded with the EM7355. Then those numbers are transmitted via your SIM through a GSM connection provided by the carrier .Finally the codes are arriving to the other SIM and converted with the opposite device DAC (digital to analogue converter) so you can hear a voice. This is the simplest explanation. Actually a GSM ,GPRS,3,4,5 G module could be fitted in 1 cm^2 .Anyway as soon I’ve got the device I will inform you if it does the data calls(not internet). Unfortunately just saw the estimated delivery is in 5 -7 days.
You must choose radio for your thinkpad unless you hack vendor ID it will not be seen I had to do this for my tough book when I used dell radio em7355.
I spent many hours farting around with this radio that test software doesn’t allow you to hear/transmit anything it does not decode or enclose audio it just issues ata commands the same you can do in a terminal. Anyways it only takes me a few minutes to reload that software and confirm. These is a note on the manual for this radio saying “FW for voice is a future FW update”
You may want to read the developer section. There is indication that you can get SDK for android and Linux.
Probably you’re right. I just have college degree( not university ) in electrical engineering and advanced digital electronics and just thinking in a logical way .Probably you are more informed about the subject and already have tested it with this program. Anyway it shouldn’t be impossible to write a software when you already have all the hardware components ,by the way I just found some information about this software and is written that you can start a voice call with a certain command .Maybe is just for testing without actual coding -decoding.You can take a look.https://m2msupport.net/m2msupport/voice-call-at-commands-to-set-up-voice-call/
