I have approximately 30 EM7345 deployed and 3 of them (so far) exhibit an unexpected behaviour. After a few days of staying connected with the first GSM network, they start restarting continuously with the dmesg errors cdc_mbim 1-1.1:1.0: nonzero urb status received: -71 and cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes, This happens continuously until changing the SIM card to one from a different GSM provider. Then, they each start working as expected again, with the second one. Here are the debugging notes so far:
Telekom Romania SIM worked for approximately 5 days, then:
[ 68.699886] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 68.699906] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 68.704882] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 68.704896] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 68.709882] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 68.709897] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 68.714886] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 68.714900] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 68.716643] usb 1-1.1: USB disconnect, device number 11
[ 68.717129] cdc_mbim 1-1.1:1.0 wwan0: unregister 'cdc_mbim' usb-0000:01:00.0-1.1, CDC MBIM
[ 69.070003] usb 1-1.1: new high-speed USB device number 12 using xhci_hcd
[ 69.171239] usb 1-1.1: New USB device found, idVendor=8087, idProduct=0716, bcdDevice= 0.00
[ 69.171249] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 71.533254] usb 1-1.1: USB disconnect, device number 12
[ 76.042038] usb 1-1.1: new high-speed USB device number 13 using xhci_hcd
[ 76.149930] usb 1-1.1: New USB device found, idVendor=1199, idProduct=a001, bcdDevice=17.29
[ 76.149988] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 76.150006] usb 1-1.1: Product: Sierra Wireless EM7345 4G LTE
[ 76.150021] usb 1-1.1: Manufacturer: Sierra Wireless Inc.
[ 76.150035] usb 1-1.1: SerialNumber: 013937006806044
[ 76.216031] cdc_mbim 1-1.1:1.0: setting rx_max = 16384
[ 76.217268] cdc_mbim 1-1.1:1.0: cdc-wdm0: USB WDM device
[ 76.218353] cdc_mbim 1-1.1:1.0 wwan0: register 'cdc_mbim' at usb-0000:01:00.0-1.1, CDC MBIM, f6:8c:31:66:54:19
[ 76.226716] cdc_acm 1-1.1:1.2: ttyACM0: USB ACM device
[ 81.756908] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 81.756955] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 81.761908] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 81.761942] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 81.766908] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 81.766937] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
Orange Romania SIM makes the modem work again:
mmcli -m any
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: fcbbf376865087eeba8c53f21f6d27f185727ad8
Hardware | manufacturer: Sierra Wireless Inc.
| model: Sierra Wireless EM7345 4G LTE
| firmware revision: FIH7160_V1.2_WW_01.1616.01
| h/w revision: XMM7160_V1.2_MBIM_GNSS_NAND_RE
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 013937006806044
System | device: /sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1
| drivers: cdc_mbim, cdc_acm
| plugin: sierra
| primary port: cdc-wdm0
| ports: cdc-wdm0 (mbim), ttyACM0 (at), wwan0 (net)
Status | lock: sim-pin2
| unlock retries: sim-pin2 (3)
| state: connected
| power state: on
| access tech: gprs, umts
| signal quality: 54% (recent)
Put the Telekom Romania SIM card back in:
[ 45.770572] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 45.770601] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 45.775572] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 45.775601] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 45.780574] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 45.780603] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 45.785548] cdc_mbim 1-1.1:1.0: nonzero urb status received: -71
[ 45.785560] cdc_mbim 1-1.1:1.0: wdm_int_callback - 0 bytes
[ 45.787273] usb 1-1.1: USB disconnect, device number 7
[ 45.787791] cdc_mbim 1-1.1:1.0 wwan0: unregister 'cdc_mbim' usb-0000:01:00.0-1.1, CDC MBIM
[ 46.160204] usb 1-1.1: new high-speed USB device number 8 using xhci_hcd
[ 46.261440] usb 1-1.1: New USB device found, idVendor=8087, idProduct=0716, bcdDevice= 0.00
[ 46.261449] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Unfortunately, I have a different EM7345 which throws the nonzero urb status received: -71 errors with Orange Romania SIM cards, so using Orange exclusively with EM7345 doesn’t seem to be an option.
What can I do to debug or solve the continuously resetting behaviour?
