So the next question is how do I stop using :default and use a stream I created?
Should I ask this in a new thread?
PS
note the first time I posted this I missed the “;” of the console.log (too much python lately) the event handler ran twice but then croaked on subsequent calls by the Octave system
Hello John,
In the past, you could create a stream on the fly from an edge action. This is not possible anymore due to mess created by folks in development mode. You have to actually create a stream via the UI or via Octave API.
You can then point your edge action to the stream that has been created.
As fyi, streams can be created under the device or under your account. Streams not created under the device, can be seen in UI via the cloud - streams folder in Octave
