I have listed the location of the drivers below.
Windows - The drivers are held at the link below, one point about then is that you need to make sure that the MC73 you are plugging into your system has 5.x or newer firmware on it (only an issue for MC7304) otherwise when you plug the unit in it runs a god risk of blue screening your PC.
Linux - The GobiSerial and GobiNet drivers which are required are held on the Linux SDK share point which you need to get a login for, you need to contact your commercial channel to get you access to this. The question has been asked to put these on the developer zone which might happen.
