I’m looking into working with the MC7354 for a custom drive-test solution paired with JDSU’s E6474A drive test software. This requires exposure of the DM and AT ports under the “Ports (COM & LPT)” section of the Windows device manager.
We’ve used the Sierra Wireless 313U in the past with success, but we’re looking into the MC7354 now and I’ve learned that even with drivers installed (from here: source.sierrawireless.com/resour … uild-4208/) it only seems to expose the DM port. Is there any way to get the AT Port exposed here as well?
Hi! Please help! MC7354 does not expose nor COM port nor modem. It says that modem is not connected. But Skylight works ok. Please help me, how do I send AT Commands?
You uninstall all the drivers available in your PC and restart your PC. Then install the above mentioned drivers and then restart your PC and see if the issue is still there…
If the unit is in MBIM mode then you need a specific tools from Sierra to get it out of this configuration. It is quite difficult, once it is setup like this to get it out as there is no generic interface which can set it up i.e. QMI, AT commands, etc.
You are going to need to go via your support channel.
