The at!gstatus? shows ‘0’ on the DIV. So looks like it is correct?
AT$LGTRBAND?
AT$LGTRBAND?
$LGTRBAND: 2100,1
at!gstatus?
at!gstatus?
!GSTATUS:
Current Time: 17364 Temperature: 47
Reset Counter: 1 Mode: ONLINE
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: NO SMS,NO VoIP
LTE band: B1 LTE bw: 15 MHz
LTE Rx chan: 326 LTE Tx chan: 18326
LTE CA state: INACTIVE
RRC state: RRC Connected
PCC RxM RSSI: -81 RSRP (dBm): -108
PCC RxD RSSI: -78 RSRP (dBm): -105
Tx Power: – TAC: 0BCD (3021)
RSRQ (dB): -9 Cell ID: 091C6620 (152856096)
SINR (dB): 9.4
AT$LGTRBANDST=2100,2
$LGTRBANDST: 1
at!gstatus?
at!gstatus?
!GSTATUS:
Current Time: 17400 Temperature: 47
PCC RxM RSSI: -83 RSRP (dBm): -109
PCC RxD RSSI: 0 RSRP (dBm): 0
RSRQ (dB): -10 Cell ID: 091C6620 (152856096)
SINR (dB): 6.0
AT$LGTRBAND?
AT$LGTRBAND?
$LGTRBAND: 2100,2
AT!RESET
AT!RESET
AT$LGTRBAND?
AT$LGTRBAND?
$LGTRBAND: 2600,1
at!gstatus?
at!gstatus?
!GSTATUS:
Current Time: 50 Temperature: 46
LTE band: B7 LTE bw: 10 MHz
LTE Rx chan: 3000 LTE Tx chan: 21000
RRC state: RRC Idle
PCC RxM RSSI: -74 RSRP (dBm): -106
PCC RxD RSSI: -80 RSRP (dBm): -111
RSRQ (dB): -13 Cell ID: 091C6602 (152856066)
SINR (dB): 10.0
AT$LGTRBANDST=2600,2
$LGTRBANDST: 1
at!gstatus?
at!gstatus?
!GSTATUS:
Current Time: 87 Temperature: 46
PCC RxM RSSI: -83 RSRP (dBm): -106
RSRQ (dB): -11 Cell ID: 091C6602 (152856066)
SINR (dB): 8.4
As you can see in the AT commands above, after reset, it seems to default to MIMO, but may be there is some !custom command to make it a persistent change?
Regards,
Sai
