The problem for us is that the pcb exists and we have no gpio available on the design. I will prefer software solution if possible…
Thanks for your quick reply,
I think the only “software solution” would be AT+CPOF. This will turn off the module (only if the on/off PIN is not ON all the time) thus also shut down power to the SIM, but you’ll need to manually turn on the module again (unless you have some external circuit that controls the on/off Pin).
To complicate a little more the problem, the device is installed in the dashboard of many trucks. We must have automatic software solution without any operator manipulation…
If I do an at+cfun=1, the wavecom power off the sim card. I will do this after 20 retries of reconnection. I hope that it will solve the problem.
