Hi friends,
Is it possible to disable the unsolicited result code “RING” during incoming call?
regards
roy
Hi friends,
regards
roy
With or without your own Open-AT application?
Hi
Check the AT command guide for at+wrim. It might do the job…
No, this command just defines hardware Ring signal mode.
But the AT Commands Manual is certainly the place to be looking for this information…
Certainly…
At least Q24 manual have nothing at this point.
RING indication can be blocked by ATQ1. But nothing can stop CONNECT or NO CARRIER messages.
With open AT application some other options available, NO CARRIER can be dealed with.
But CONNECT behaviour is one BIG BUG. I know one method to disable it, but only at the cost of other problems.
I wouldn’t call it a bug.
It is, effectively, a “Solicited” response - it’s what confirms the transition from command mode to online mode.
Without the CONNECT indication, you would have no way to know when you’re actually connected…
Really? ![]()
Anyway, i mean other bugs.
