unfortunately it’s not possible to use the devstudio on my ubuntu.
you cannot install devstudio-legato via apt-get! You have to install devstudio-product. If you want to install legato IDE feature, it will fail, because there is no gdb under /opt/swi
-> this is a epic fail of outdated legato devstudio documentation. No will from my side to play around with github and other stuff to complete trash my system.
If i download the devstudio-linux32.zip, extract and run, I’m able to install the Legato IDE features and Packages for 14.10 (native) Release. Juhu, thats more than point 1! But creating projects will fail with:
java.util.NoSuchElementException
at java.util.HashMap$HashIterator.nextEntry(HashMap.java:925)
at java.util.HashMap$KeyIterator.next(HashMap.java:956)
at com.swi.cdt.settings.project.AbstractCdtProjectHelper.createCdtDescription(AbstractCdtProjectHelper.java:168)
at com.swi.ebs.commons.core.newproject.EBSProjectManager.handleProjectCreation(EBSProjectManager.java:369)
at com.swi.ebs.commons.core.newproject.EBSProjectManager.createProject(EBSProjectManager.java:153)
at com.swi.ebs.commons.core.newproject.EBSProjectManager.createProjectInWorkspace(EBSProjectManager.java:90)
at com.swi.ebs.commons.ui.wizards.EbsProjectWizard.doCreateProject(EbsProjectWizard.java:112)
at com.swi.ebs.commons.ui.wizards.EbsProjectWizard$1.run(EbsProjectWizard.java:73)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Please tell my how to proper install the devstudio on my ubuntu 12.04. As the stack trace shows errors in EBS, it’s possible to face a operating system here. Maybe a conflict with icedtea-jre v1.7?!
I have several other eclipse instances installed, they all work fine!
As you noticed, apt-get refuses to install Legato IDE because you’re running a 32 bits Linux.
cf viewtopic.php?f=177&t=8692&hilit=create+project#p35664
Can you consider migrating to 64 bits Linux, or are there other software that are preventing you to do so?..
From the thread it’s read like only docker has this 64-bit restrictions! I can download a 32-bit-zip archive of devstudio but cannot use it?! That’s sensless, sorry.
Is there a way to proper use /opt/swi-installed toolchain and framework?! My plan is to clone the git and reference it inside eclipse. Please name some instructions to do so. Will it work if I install the Legato IDE feature over an existing eclipse?
DS 3.4 will allow to install a “/opt/swi” manually extracted toolchain as a toolchain package, which can then be used to build projects. To be functional with a 32 bits toolchain, this will have to be used with a manually built Legato Framework, also installed as a package from the Package Manager perspective.
The NoSuchElementException in Java is thrown when one tries to access an iterable beyond its maximum limit. This means that, this exception is thrown by various accessor methods to indicate that the element being requested does not exist . The next() method in Java returns the next element in the iteration or NoSuchElementException if the iteration has no more elements.
As with most programming languages, the Iterator class includes a hasNext() method that returns a boolean indicating if the iteration has anymore elements. If hasNext() returns true, then the next() method will return the next element in the iteration otherwise raise exceptions if the iteration has no more elements.
if(input.hasNextInt() )
number1 = input.nextInt(); // if there is another number
else
number1 = 0; // nothing added in the input
