Hi While development phases and pre production testing is there an environment that can be used to not cluster the production environments? Adding a device and then deleting it is a bit cumbersome.
I Ian, we recommend to setup different companies for development and production.
As a user you can access several companies and switch from the UI from one to another, devices are isolated in each company.
Please reach out to your usual contact at Sierra to get this done for you.
Regards,
Hi Didier,
I currently am registered with two companies and these are the ones that I need access to Augustin has been kind enough to get me setup.
Thanks for your advice.
Ian
Thanks Didier, I guess that is a good solution and a valid option.
