Hi I just noticed something strange, if I flash my 2687 I can either choose (G) or (H) that I can understand but I am able to flash it as either one.
Now I have received some units back from technicians which where flashed using DWLWin and some say they used G and others say they used H, now I know that the G version has more rom/ram, but how do I know which is which?
M2M studio reports it as what ever version was used to flash it, and I can’t really see any markings on the sticker on the unit except for an “h” at the end on the bottom of the unit sticker, can that be it?
Also will it cause problems if it is flashed as the wring version, my gut says yes especially in the addressing of available memory.
Thing is I need a physical way apart from, At commands. Like I mentioned before I can flashed these units as either G or H and then the ATI3 response, returns what ever I flashed it as. Think the g or h on the barcode might be it.
You can’t rely on ATI3 - this is the module version reported from the Firmware, not the Hardware. As the original poster noted, it is possible to use DWLWin to flash the wrong firmware into a module (i.e. flash a ‘H’ with the ‘G’ firmware) - which may or may not break the module - and will return the wrong value from ATI3…
And that AT+WHWV doesn’t return something more meaningful than a cryptic version number - or at least that Wavecom could prove some sort of decode table for this number…
