What is the firmware version used in WISMO, when the problem is seen.
Is CSD call not working with a particular firmware ?Did you check with other firmware versions as well?
All the tested modules have the same firmware version or you tested on different versions?
The version string is “L20_00gg.WISMO228 270410”. All modules that I have tested have the same firmware version.
I think it is too old but I can not find anything relating to the firmware. Nor the firmware downloader nor the new firmware for WISMO228.
Yes, of course. The previous version of the GSM modem on the Q24 module all works fine in the same conditions.
Yes, of course. I tried contact to the local disributor. There is no info at all. Two last months each time it says “wait two weeks for the new firmware version”. But nothing happens. No firmware downloader nor firmware.
