I have 2 modules that started to respond to the AT+CPIN? command, +CPIN: PH-NET PIN.
From what I researched this means that the modules have become locked to a mobile network.
I’m almost sure that this happened with no user intervention!
AT+CPIN?
+CPIN: SIM PIN
AT+CPIN="9352"
AT+CPIN?
+CPIN: PH-NET PIN
I tryed to upload the firmware, but not successful! Here is the log:
04/04/2016 17:03:54'925 HUAP HiloUpgrader starting... [RELEASE]
04/04/2016 17:03:54'925 HUAP HiloUpgrader version : 5.0.4.0
04/04/2016 17:03:54'925 HUAP MobileHILO2 DLL version : 3.3.2.0
04/04/2016 17:03:54'979 HSET Serial Port count : 1
04/04/2016 17:03:54'979 HSET Serial Port list : COM1
04/04/2016 17:03:55'005 HSET UpdateMainMMI - Usable = 0x00 UnBusy = 0xFF
04/04/2016 17:03:55'050 HUAP Loader file OK : flash_nor_16bits_hwasic_evp_4901_2_rel_sc_0_6.hex
04/04/2016 17:03:55'053 HUAP Software OK : \\zen\dev\software\HI2N_A_005_08_0020_p7035D.pac
04/04/2016 17:04:01'980 HSET UpdateMainMMI - Usable = 0x01 UnBusy = 0xFF
04/04/2016 17:04:11'736 HUAP Upgrade by user
04/04/2016 17:04:11'736 HUAP Loader file : flash_nor_16bits_hwasic_evp_4901_2_rel_sc_0_6.hex
04/04/2016 17:04:11'736 HSET Main file : \\zen\dev\software\HI2N_A_005_08_0020_p7035D.pac
04/04/2016 17:04:11'739 PACF PAC file size : 3243706 bytes
04/04/2016 17:04:12'167 PACF CLA file size : 3183088 [0x003091F0] bytes (Data size : 3243704 bytes)
04/04/2016 17:04:12'175 PACF PARAM file size : 60608 [0x0000ECC0] bytes (Data size : 60612 bytes)
04/04/2016 17:04:12'178 PACF Checking software : 3183088 bytes
04/04/2016 17:04:12'186 PACF Get software version from CLA file : SAGEMCOM Hi2N,A.005.08 [Offset : 0x003091F0]
04/04/2016 17:04:12'215 PACF Compute MD5 fingerprint of CLA file : 20EE71CD6CCD901B1C393E1B6EFA23B8
04/04/2016 17:04:12'216 HSET Software : HI2N_A_005_08_0020_P7035D_HU.CLA
04/04/2016 17:04:12'216 HSET Parameter file : HI2N_A_005_08_0020_P7035D_HU.PARAM
04/04/2016 17:04:12'216 HSET DetectModule : Enable
04/04/2016 17:04:12'230 MOD1 Step: Initialisation
04/04/2016 17:04:12'230 MOD1 Step: Detect module
04/04/2016 17:04:12'230 ATC1 Detect Module at COM1
04/04/2016 17:04:12'230 ATC1 Checking COM1 @ 115200 bauds
04/04/2016 17:04:12'430 ATC1 W (1) 00
04/04/2016 17:04:12'441 ATC1 W (3) 41 54 0D
04/04/2016 17:04:12'622 ATC1 R (9) 41 54 0D 0D 0A 4F 4B 0D 0A
04/04/2016 17:04:12'622 ATC1 W (8) 41 54 2B 43 47 4D 52 0D
04/04/2016 17:04:13'004 ATC1 R (40) 41 54 2B 43 47 4D 52 0D 0D 0A 53 41 47 45 4D 43 4F 4D 20 48 69 32 4E 2C 41 2E 30 30 35 2E 30 33 0D 0A 0D 0A 4F 4B 0D 0A
04/04/2016 17:04:13'005 MOD1 Found Speed : 115200 bauds
04/04/2016 17:04:13'005 MOD1 Software version : SAGEMCOM Hi2N,A.005.03
04/04/2016 17:04:13'005 MOD1 Step: Generate SAV file
04/04/2016 17:04:13'006 DLL1 CFG : 04.00.00 - 13/01/2011 (Hilo V1/V2 management)
04/04/2016 17:04:13'107 DLL1 OpenSession COM1 @ AT:115200 bauds TAT:115200 bauds ...
04/04/2016 17:04:16'337 DLL1 TAT Session is opening (5) ...
04/04/2016 17:04:28'367 DLL1 Platform : [DEFAULT_PLATFORM] - Specific : [HiloV2_DV1.24]
04/04/2016 17:04:28'367 DLL1 HILO V2 MODULE READY FOR TAT REQUEST
04/04/2016 17:04:28'367 TAT1 STE software version : 3700001300020124
04/04/2016 17:04:28'367 DLL1 CTATRequest::ReadSerialNumber
04/04/2016 17:04:28'371 TAT1 HILO Serial Number : 1341316437
04/04/2016 17:04:28'381 DLL1 ReadSectionInfo ID:18 Size:0x0028 - Address:0xA802E474
04/04/2016 17:04:28'482 DLL1 CTATRequest::ReadMemory
04/04/2016 17:04:28'492 TAT1 Checking HILO module : 355278056345989
04/04/2016 17:04:28'502 DLL1 ReadSectionInfo ID:37 Size:0x0408 - Address:0xA802D8B0
04/04/2016 17:04:28'512 DLL1 ReadSectionInfo ID:37 Size:0x0408 - Address:0xA802D8B0
04/04/2016 17:04:28'613 DLL1 CTATRequest::ReadMemory
04/04/2016 17:04:28'708 TAT1 Checking HILO module : Invalid software key
04/04/2016 17:04:28'711 DLL1 TAT:CloseSession
04/04/2016 17:04:28'712 DLL1 CloseSession
04/04/2016 17:04:28'813 SAV1 Searching for a valid SAV file ...
04/04/2016 17:04:28'814 SAV1 Searching for a valid [SA_] file ...
04/04/2016 17:04:28'814 MOD1 Step: Generate SAV file: No SAV file and default Software Key
04/04/2016 17:04:28'814 DLL1 CloseSession
04/04/2016 17:04:28'814 HUM1 UserMessage [181] : Software key of the module is an Invalid Software Key!
04/04/2016 17:04:28'816 PACF Deleting temporary files...
04/04/2016 17:04:28'817 PACF Delete file : HI2N_A_005_08_0020_P7035D_HU.PARAM
04/04/2016 17:04:28'830 PACF Delete file : HI2N_A_005_08_0020_P7035D_HU.CLA
04/04/2016 17:04:42'076 HUAP HiloUpgrader closing
04/04/2016 17:04:42'077 HUAP ********************
04/04/2016 17:04:42'086 HLOG MD5 Fingerprint : 15EAF1B2D23C745EC737D57E0B292338
Is there anything that can be done to recover the modules?
What could have happened to make the modules behave like this?
Thanks.
