Does anybody know how to use Correction Factor with Wavecom Module? I´m using 2501Q.
This is because i get Coordinates from the GPS and I want to plot some points at a MAP.
I´m in Brazil and there´s some correction to do…
Henrique
Henrique
Hi!
I´ve found out that I can get the Geoid correction from Position Structure.
/* Position structure */
typedef struct
ascii UTC_time [_S_UTC_TIME]; /* hhmmss.sss */
ascii date [_S_DATE]; /* ddmmyy */
ascii latitude [_S_POSITION]; /* ddmm.mmmm */
ascii latitude_Indicator[_S_INDICATOR]; /* N - S */
ascii longitude [_S_POSITION]; /* dddmm.mmmm */
ascii longitude_Indicator[_S_INDICATOR];/* E - W */
ascii status[_S_INDICATOR];
ascii P_Fix[_S_INDICATOR];
ascii sat_used [_S_SAT]; /* Satellites used */
ascii HDOP [_S_HDOP]; /* Horizontal Dilution of Precision */
ascii altitude [_S_ALTITUDE]; /* MSL Altitude */
ascii altitude_Unit[_S_INDICATOR];
ascii geoid_Sep [_S_GEOID_SEP]; /* geoid correction */
ascii geoid_Sep_Unit[_S_INDICATOR];
ascii Age_Dif_Cor [_S_AGE_DIF_COR]; /* Age of Differential correction */
ascii Dif_Ref_ID [_S_DIF_REF_ID]; /* Diff Ref station ID */
ascii magneticVariation[_S_COURSE]; /* magnetic variation : not available for sirf technology */
} adl_gpsPosition_t;
Can I change the Correction data? Is there any document that specify the changes!?
Thanks once again!
Henrique
I use Q2501 and I noticed that the GPS NMEA Polling is already set to my zone and there´s no need for any kind of configuration.
One thing I also noticed is that the format available of latitude and longitude is in Degree, Decimals… and not in DDº MM´ SS´´
Hope this information may help someone…
