Hi everyone!
I´m getting NMEA string from the GPS and it says eg. my latitude is -19,58°
I know it´s wrong!
Then… I use a program called U-BLOX and it gets the same NMEA string and the -19,58° and it shows me that the Tracker I´m using is at -19,96° which is correct!
What kind of correction is U-BLOX doing? Does anybody know!?
I plugged the UART2 of the Wavecom 2501 Module in the PC serial interface. It starts to poll NMEA string and show -19,58°.
Anybody use to correct those coordinates!?
Thanks a lot!
Henrique
In the NMEA string the coordinate is in degree + minute format.
58 minute is appr. 0.96 degree. So -19 degree 58 minute (-19,58’) is
-19,96 degree.
tom
Hi Tom! Thanks for the reply!
But… 58’ is a big error comparing to 96’!
When I plot it on a map I see it´s a huge error! There´s a waypoint I know it’s exact location ok? When I bring the GPS to this location and try to plot the coordnates it gives, it´s like miles away!
Do I always have to consider 96’-58’= 38’ error?
Don´t you think 0.38 degree is a little big app.?
I´m sorry if I didn´t uunderstand your point…
Thanks for the help!
Henrique
Sorry if i am understanable. That is not an error, just an other format.
One degree is 60 minute. 0,96 degree is 58 minute so comes that -19 degree 58’ minute is equal with -19,96 degree.
tom
I got it now!! Thanks! That really make sense!!!
Do you know the names of these formats?
How is this conversion made? 58’ to 96’… with one point I couldn´t figure out a pattern.
Best Regards,
Henrique
