Connection between RV50X- UNable to connect
I am having below issue:
ALEOS_VPN_SwanMgr: VPN FO disabled: both primary and secondary must be enabled
Apr 8 16:03:20 err ALEOS_VPN_SwanMgr: Can’t configure any enabled tunnels
Hi @J4521,
  • Based on the provided log, I understand that you are experiencing issues with configuring the VPN tunnel, is that correct? If not, please provide more detailed information about the issue you are facing.
  • Which ALEOS version and radio module firmware is the RV50X currently running?
  • If possible, please share the full log file and template file on the RV50X with me.
