Hello everyone,
How can I create a project with 2 or 3 source files and compile then ?
Have you ever tried something like this, using Open AT ???
Tks for all,
Gus
Hello everyone,
Tks for all,
Gus
Guys,
I am still trying to compile more than one source file.
I added a new source file in the directory /src and, using Open AT Project Wizard, I reopened the project.
When I tried to compile I got the following error
make: *** No rule to make target `funcoes.o', needed by `gcc_SourcesV1_32'. Stop.
funcoes.o is the new source file
SourcesV1 is the project name
Any ideias
You should check your make file manually. The important part for us is located in the main directory of your project, with name like “your_project.mak” .
Look at the SRC_C_LIST, it should look like this with the files to compile:
# List of source files of the library or executable to generate
SRC_C_LIST = \
appli.c \
gprs.c \
riaszt.c \
t_at.c \
sms.c \
system.c \
time.c \
gps.c \
ei_ftp.c \
compress.c \
Make sure that your files are really in the src sub-directory.
And the include files should be in the itf or inc directory with this settings:
PATH_H =
…/…/inc
…/…/itf \
In visual C++ use “add–>add existing itim” on your rte project.
good luck,
tomalex
Hello everyone,
If you are using cygwin and adds a new soruce/s file/s to your .mak file or .scs file (this modifies the .mak file automatically).
You have to rebuild dependencies file with:
wmmake youproject -c
-c (Cleans all dependencies tree)
This command modifies the gcc/out/yourfileproject_B.dep file introducing how must be compiled your new sources
You can modify the .dep file manually but I thin the best process is
I hope this advice can help you.
Regards,
Javier
It is working !!!
Tks for all,
Gus
i have a similar problem… I would like to create a tree in my project under Eclipse. So, under Eclipse, i create a new src folder (named “uart1”), which contains a file “al_uart1.c” (also created under Eclipse IDE).
When i compile, i have the following error :
[color=green]make: *** [make_single_bin] Error 1
d:/Programmes/Wavecom-OpenAT/WorkSpace/Telem/mingw/out/appli.c:85: undefined reference to `AL_UART1_SystemOut’
Done.
Updating RTE kernel file…
no generated DLL found…
[wmmake error #1] Build error.
The function AL_UART1_SystemOut contained in al_uart1.c is not found.
So, as described above, i modified the file *.scs in my project path directory. I add the following lines :
[color=darkred]
./src
./Telem/uart1
After that, my program compiles without any problems. But, Next time i open the project thanks to Project Wizard, the file *.scs has lost the previous informations … the project Wizard has cleared it… So i must to re-write it…
Why these informations are lost ? how can i save it ?
Best regards
