Thanks for the help I done this already
I am trying to build test empty project and have some problems I will be grateful if you can help me
After open new Lua Project and compile i get this error for missing function
src-bytecode\TestLua1_main.o: In function luaopen_TestLua1_main': ..\src-bytecode/TestLua1_main.c:19: undefined reference toluaW_openBytecodeTable’
Build error occurred, build is stopped
I add this two function that i think is missing I hope I am right:
find_global
and now I can load the application to the modem but there is problem to find one of the module
My module.
error from console:
------------- Start Program -------------.
[MEM] Reserving 2600 bytes out of 104160 for 8-blocks pool
[MEM] Reserving 5160 bytes out of 104160 for 16-blocks pool
[MEM] Reserving 19320 bytes out of 104160 for 20-blocks pool
[MEM] Reserving 23160 bytes out of 104160 for 24-blocks pool
[MEM] Reserving 9000 bytes out of 104160 for 28-blocks pool
[MEM] Reserving 20560 bytes out of 104160 for 32-blocks pool
[MEM] Reserving 24360 bytes out of 104160 for 76-blocks pool
[LUAW] load library oatlua…[LUAW] load oatlua / generic
[LUAW] load generic / base
[LUAW] load generic / table
[LUAW] load generic / string
[LUAW] load generic / package
[LUAW] load generic / debug
[LUAW] load generic / time
[LUAW] load generic / misc
[LUAW] flashload ‘misc’ 0x2a064c… done.
[LUAW] load generic / os
[LUAW] load generic / schedtimer
[LUAW] flashload ‘schedtimer’ 0x299c50… done.
[LUAW] flashload ‘sched’ 0x29aa40… done.
[LUAW] load generic / log
[LUAW] flashload ‘log’ 0x2a0e28… done.
[LUAW] load generic / mem
[LUAW] load generic / sms
[LUAW] flashload ‘sms_lua’ 0x2b1854… done.
[LUAW] load generic / at
[LUAW] flashload ‘at_lua’ 0x2ac3e0… done.
[LUAW] load generic / uart
[LUAW] flashload ‘uart_lua’ 0x2afffc… done.
[LUAW] load generic / pipe
[LUAW] flashload ‘pipe’ 0x29f7e0… done.
[LUAW] load generic / bit
[LUAW] load oatlua / wip
[LUAW] load wip / options
[LUAW] load wip / channels
[LUAW] flashload ‘channels_lua’ 0x2a3f2c… done.
[LUAW] load wip / bearers
[LUAW] flashload ‘bearers_lua’ 0x2aa254… done.
[LUAW] load wip / tcp
[LUAW] flashload ‘tcp_lua’ 0x2b0b10… done.
[LUAW] load oatlua / flash
[LUAW] load flash / flash_read
[LUAW] flashload ‘flash_read_lua’ 0x2a343c… done.
[LUAW] load flash / flash_write
[LUAW] flashload ‘flash_write_lua’ 0x2a1c20… done.
[LUAW] load flash / rawflash
[LUAW] flashload ‘rawflash’ 0x29dd70… done.
[LUAW] load flash / ad
[LUAW] flashload ‘ad_lua’ 0x2aded0… done.
[LUAW] load oatlua / interactive
[LUAW] load interactive / shell
[LUAW] flashload ‘shell’ 0x29726c… done.
[LUAW] load interactive / print
[LUAW] flashload ‘print’ 0x29e1c8… done.
[LUAW] load interactive / bootload
[LUAW] flashload ‘bootload’ 0x2a6e7c… done.
[LUAW] load interactive / at_plus_lua
[LUAW] flashload ‘at_plus_lua’ 0x2ac0c8… done.
uses 86616 bytes
[LUAW] load library strict…[LUAW] flashload ‘strict’ 0x296abc… done.
uses 1158 bytes
+LUALOG: “sched”,“DETAIL”,“RUN [thread 0x18121260]”
+LUALOG: “require”,“INFO”,“require ‘TestLua1.main’: begin”
[LUAW ERROR] *** src-lua\bootload.lua:190: Unable to load module TestLua1.main:
no field package.preload[‘TestLua1.main’]
Can’t load ‘TestLua1/main’ from network, DOWNLOAD_CONFIG not set
[LUAW] run(): error: src-lua\bootload.lua:190: Unable to load module TestLua1.main:
[LUAW] stack traceback:
[C]: in function ‘error’
src-lua\bootload.lua:190: in function ‘find_module_loader’
src-lua\bootload.lua:202: in function ‘require’
[string “require ‘TestLua1.main’; main()”]:1: in main chunk
+LUALOG: “sched”,“DETAIL”,“SIGNAL [thread 0x18121260].die”
------------- End Exit Program -------------.
Please advice how i can solve this problem.
Please Help.
DZ
