Can't enter Data State
I’m trying to activate an IP PDP context on my SL6087 in order to send data using AT commands. Here is the AT sequence I’ve used:
at+cgatt=1
at+cgdcont=1,“IP”,“movistar.pe”
at+cgact=1,1
at+cgdata=1
+CME ERROR: 3
As you can see everything is OK except when I type +CGDATA. Apart from that, I’ve tried to connect to a GSM network operator but I can’t, so I don’t know if these two issues are related. I get the following:
at+cops=?
+COPS: (0,“movistar”,“movistar”,“71606”) // The ‘0’ parameter means (acoording to the Interface Guide) unknown network. I don’t know how to fix this either.
Any ideas will be welcome.
I’ve realized that an APN has an ID user and a password but I haven’t made use of this data. Does anyone know the AT command to enter this data?
Thanks in advance
rnole
hi:
if you use SL6087 to transfer data by tcp/ip ,advice to use wipsoft.
about your problem,you must enter atd99**# to dial before AT+GPRSDATA
