Cannot update FW success in R16
I cannot download the FW success.
My step is below:
Failed steps:
  1. update to R16 generic image.
  2. modify some init file in yocto source then compile.
  3. update to custom image. (This time will be success)
  4. modify some init file in yocto source then compile.
  5. update to custom image. (This time will be failed)
I always can update success when I update to R12 and do reset then update to original R16 and update custom R16 image.
So I want to know where R17 is supported reset command?
what reset command do you mean?
Here says you cannot downgrade after upgrading to R17:
https://source.sierrawireless.com/resources/airprime/software/wp76xx/wp76xx-firmware-release-17/#sthash.9jSgC307.dpbs
Like R12 swiflash -m wp76xx -r erase USER partition
BTW I use swiflash to update SPK file
It seems no response
and console stuck
starting from R13, you cannot run that, you need to delete the userapp partition manually
e.g.
Does it same as USER1 partition?
didn’t it say it is erasing userapp partition?
So I need like “-r” command to reset USER1 partition
have you checked this?
Hi @jyijyi ,
I am trying it now.
Wait for my test.
Hi @jyijyi ,
I try the method I think it work for update, because it will restore the file.
