Cannot enable EM9293 GPS feature
I used follow commands to enable EM9293 GPS
AT!CUSTOM=“GPSENABLE”,1
AT!CUSTOM=“GPSLPM”,0
AT!CUSTOM=“GPSSEL”,0
AT+WANT=1
AT!GPSFIX=1,255,10
and then I used AT!GPSSTATUS? and AT!GPSLOC? to get GPS status
AT!GPSSTATUS?
Current time: 1980 01 06 6 00:09:16
1980 01 06 6 00:09:16 Last Fix Status = NONE
1980 01 06 6 00:08:46 Fix Session Status = ACTIVE
No TTFF available
AT!GPSLOC?
Not Available
It looks didn’t work, how do I enable EM9293 GPS feature?
Which firmware are you using?
did you connect GPS antenna?
Did you check aT!GPSSATINFO? to see if any satellite can be viewed?
BTW, are you testing in outdoor area?
  1. Firmware version:SWIX65C_02.17.08.00 944ad5 jenkins 2024/08/01 20:22:05
  2. Yes, I have connected GPS antenna
  3. Yes, but I cannot see any information of satellite
  4. I didn’t go outdoor area to test
you are using standalone mode for AT!GPSFIX, it will not work if it does not see satellite
Do you mean I need to use AT!GPSFIX to set MS-based or MS-assisted mode ?
I would suggest you to do it in outdoor with standalone mode to make sure it can view the satellite first
Okay, thanks, I will try it first
I tested GPS on outdoor area, though I still cannot see statellite information when I use AT!GPSSATINFO?", but I used AT!GPSSTATUS? and AT!GPSLOC? can see “SUCCESS” and location information, so do I success enable GPS feature ?
AT!GPSSTATUS?
Current time: 1980 01 06 6 00:13:15
1980 01 06 6 00:12:58 Last Fix Status = SUCCESS
1980 01 06 6 00:12:58 Fix Session Status = SUCCESS
TTFF (sec) = 2
AT!GPSLOC?
Lat: 24 Deg 46 Min 52.32 Sec N (0x00467D1F)
Lon: 120 Deg 59 Min 57.82 Sec E (0x01582D12)
Time: 2025 06 27 4 06:25:14 (GPS)
LocUncAngle: 0.0 deg LocUncA: 8 m LocUncP: 3 m HEPE: 8.544 m
2D Fix
Altitude: 117 m LocUncVe: 9.1 m
Heading: 0.0 deg VelHoriz: 0.0 m/s VelVert: 0.0 m/s
seems it already can get location with correct time and location
are you using standalone mode in AT!GPSFIX?
Yes, I used standalone mode in AT!GPSFIX?
then that means it is already using satellite information
Dose firmwave SWIX65C_02.13.08.00 have GPS feature? Do I need to upgrade firmwave for GPS feature ?
why don’t you upgrade to the latest one?
FW 2.13.08.00 is quite old, almost two years ago
Because my colleague at remote site uses FW 2.13.08.00, but he cannot enable GPS feature, so I am not sure if it is firmware too old problem
you can upgrade the firmware with other PRI and check
