Can I redefine the action of an AT command embedded in OpenAT?
I want to overwrite or hook the action of the ATD command.
When I registered ATD command and call “ATD=”, It does the action that I expected.
However, when I call “ATD”, embedded ATD is called and does not do the action that I expected.
My development environment is following.
Developer Studio : version 2.3.1
LSI of communication unit : SL8084T
Communication unit : AX8084NE
ATD command is very special and doesn’t follow the general format defined into the AT commandz specification.
I suggest this:
subscribe to all AT commands starting by ATD using adl_atCmdSubscribe or adl_atCmdSubscribeExt: use ADL_CMD_TYPE_ROOT_EXT option into the API.
Into the command handler, use the StrData field of the structure adl_atCmdPreParser_t to get the full command and parse it to get the phone number (the phone number will not be present into the ParaList).
I think the final “;” will be filtered so you will certainly loose this indication.
