is there anyone who can help me to stream audio from my phone to BX3105 dev kit audio out and thank you?
Which FW is the BX3105 device using?
You can follow below steps to stream audio to BX3105:
- AT+KI2SCFG=0,1,0,0,0,0,26,18,33,32
Enable I2S port and configure parameters for I2S - AT+SRBTSYSTEM=3
Enable BTDM (BLE & BT Classic) BT subsystem mode - AT+SRBTSTATE=1,2
Set device to be general discoverable and connectable - AT+SRBTCPROFILES=6
Enable A2DP and AVRCP for Bluetooth Classic - AT+SRA2DPCODEC=1
Enable the audio codec chip on the BX3105 dev kit - Using Bluetooth on the phone connect to the device. Now, you can play the audio on the phone and audio has on BX3105’s audio out.
Don’t forget the headphone must be connected to BX3105 via Audio output connector.
