I did:
at&f
ati3
652_09gg.Q2406B 1483340 012006 15:37
at+wopen?
+WOPEN: 0
at+wbcm=3,1,4200,3400,1000,10000,150
and waited more that 2 minutes without getting any +WBCI indications…
Why do I get no battery indications? Was there a change in the API or is it yet an other bug in the firmware?
Best Regards,
Jan
—edited—
I found out that the indications will appear when the device is not on the charger!
But when I do the same command on an older firmware, the indications will also appear when the device is on the charger!
+WIND: 7
+WBCI: 3,3762
+WBCI: 3,3772
+WBCI: 3,3726
ati3
640d09gg.Q2406B 1273604 091103 18:26
+WBCI: 3,3726
Now, when I do the command in 6.52 when the device is not on the charger, it will work. But the indications will stop once the device is placed on the charger! And they won’t continue when it is removed again from the charger. What is going on here. How can I enable the indications that they are always enabled regardless of the state of charging???
Best Regards once more,
Jan
