If resolution is 16bit, and sampling rate is 44.1KHz, Bit clock for stereo should be:
2 channels X sampling rate X resolution = 2 X 44.1KHz X 16 = 1.411200MHz
not 2.822400MHz…why is the bit clock in the example is twice the calculated value?
Thanks you all
Nir
Hi
I have seen this and still it does not explain why does BCLK in not 2 x 16bit x 44.1KHz
Can you explain why 44.1KHz in multiplied by 64 and not by 32?
Nir
