BC127 only streams at 48000Hz
I have my BC127 set up as I2S slave with my host transmitting my I2S at 44.1kHz. I have the BC127 configured with:
AUDIO_DIGITAL=0 44100 64 100200 ON
Whenever I pair to a device, the connection switches to 48kHz as seen here:
STATE CONNECTED[1] CONNECTABLE[OFF] DISCOVERABLE[OFF] BLE[OFF]
LINK 10 CONNECTED A2DP F80FF9F8C973 SUSPENDED SBC SRC 48000
LINK 11 CONNECTED AVRCP F80FF9F8C973 STOPPED
Once the device is disconnected and I check the AUDIO_DIGITAL output, it shows 44.1kHz again.
My full config is here:
AUDIO=1 1
AUDIO_ANALOG=15 15 1 OFF
AUTOCONN=1
AUTO_DATA=OFF OFF
BALANCE=100 100
BATT_CONFIG=ON 170 4250 1500 150
BLE_CONFIG=0 OFF 80 ON
BLE_CONN_PARAMS=128 12 24 40 0 400 100 400 400 64 400 400
BT_STATE_CONFIG=1 1
BT_VOL_CONFIG=A 60 10 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=3 OFF
DEEP_SLEEP=OFF
ENABLE_BATT_IND=ON
ENABLE_LED=OFF
GPIO_CONFIG=OFF 0
HFP_CONFIG=OFF ON OFF OFF OFF OFF
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB0A5C4B 000000000000
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=BC-0A5C4B
NAME_SHORT=BC0A5C4B
PIN=0000
PROFILES=0 0 0 1 1 0 0 0 0 0 0 0
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
Thanks.
