Hi
I’m trying to get a PCM digital input signal to go to A2DP (src) bluetooth speaker.
Configurations:
1- Analog input signal to A2DP (src) Bluetooth speaker , OK
2- Digital Input to analog jack output OK -> (meaning PCM stream is OK)
3- Digital Input to A2DP (src) Bluetooth speaker NOT OK
I made sure that i tested both scenarios with AUDIO=1 1 and AUDIO=0 0
In no way can i get a way from the Digital input to the A2DP output.
In both situations is pressed the “play/pause” button on the dev board.
This is my Config. (note this is setup nr 1)
Only difference when using the digital input configuration is using the AUDIO=1 1
AUDIO=0 0
AUDIO_ANALOG=15 15 1 OFF
AUDIO_DIGITAL=1 48000 1536 100420 OFF
AUTOCONN=0
AUTO_DATA=OFF OFF
BALANCE=100 100
BATT_CONFIG=OFF 145 4250 1500 150
BLE_CONFIG=0 OFF 80 ON
BLE_CONN_PARAMS=128 12 24 40 0 400 100 400 400 64 400 400
BT_STATE_CONFIG=1 0
BT_VOL_CONFIG=A 60 10 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
DEEP_SLEEP=OFF
ENABLE_BATT_IND=ON
ENABLE_LED=ON
GPIO_CONFIG=ON 0
HFP_CONFIG=OFF ON OFF OFF OFF ON
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB0A00B9 43F25346E217
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=A_DevBoard
NAME_SHORT=BC0A00B9
PIN=0000
PROFILES=2 2 0 2 2 1 2 1 0 0 1 0
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
Is this behaviour with recard to NOT routing the PCM to A2DP normal??
Or am i doing something wrong
