I have an RC7611 module configured as a TCP server and use it in the Direct Data Flow mode when a client is connected. The +KTCPCFG command allows me to open the listening socket automatically on boot. But to enter the Direct Data Flow mode I have to resend the +KTCPSTART command every time a client is connecting. Wonder if is there a way to make the device accept the first incoming connection and enter Direct Data Flow mode automatically?
Here is an example of the module configuration steps I do.
These commands can be sent once and the configuration is stored on the device:
AT+KCNXCFG=1,"GPRS",APN,"",""
AT+KCNXUP=1
AT+KTCPCFG=,1,,10001,,,,,,1
Incoming connection notification:
+KTCP_SRVREQ: 1,2,IPAddress,Port
Entering the Direct Data Flow, requires sending every time a new connection is accepted:
AT+KTCPSTART=2
CONNECT
Can sending the +KTCPSTART command be avoided to make the TCP session restored fully automatically on boot without the need for an external watchdog for the module?
Please advise. Thanks in advance!
