HL7588 - Using Direct Data Flow in Server Mode
I am using a Sierra Wireless HL7588 module that is included in the Nimbelink Skywire NL-SW-LTE-S7588-T.
I would like to make use of Direct Data Flow mode. The problem seems to be when trying to use AT+KTCPSTART when I have the TCP connection set up in server mode. I can successfully use Direct Data Flow Mode and KTCPSTART when I am configured as a client. Below is a capture of the AT commands and the responses I get when trying to do this. You can see, I set up both a client and server connection. I then start the client connection successfully using KTCPSTART, send some data, and then close the connection. I do the same steps when trying to start the server mode using KTCPSTART but get an error returned.
WinTX New Capture Started: 8/27/2020 10:38:34 AM
AT+KTCPCFG?
+KTCPCFG: 1,0,1,1,"",12345,0,0,0 //SERVER CONFIG
+KTCPCFG: 2,0,1,0,“47.222.66.242”,12345,2045,0,0,0 //CLIENT CONFIG
AT+KTCPCSTART=2
+KTCP_NOTIF: 2,5
AT+KTCPSTART=2 //START DIRECT DATA MODE CONFIGURED AS CLIENT
+KTCP_IND: 2,1
CONNECT //SUCCESSFULLY CONNECTED TO SERVER
hello+++
+KTCP_DATA: 2,1
+KTCP_DATA: 2,2
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
+KTCP_DATA: 2,1
AT+KTC{PCLOSE=2 //CLOSE CONNECTION
+KCNX_IND: 1,5,30
AT+KTCPCFG?
AT+KTCPSTART=1 //START DIRECT DATA MODE CONFIGURED AS SERVER
+CME ERROR: 910 //ERROR
+KCNX_IND: 1,0,0
My question is, is it even possible to use Direct Data Flow mode as I am trying to do? If so, what am I doing wrong ?
Hi @aaron.mcneil
Which firmware version are you using (ATI3)? If you are not in the latest firmware, please download the latest one and retry.
You can get it here https://source.sierrawireless.com/resources/airprime/software/hl7588-firmware/#sthash.I6wqANCZ.dpbs
Hi @Donald,
I tried upgrading the firmware and still get the same results. I am able to use AT+KTCPSTART when using as a client, but get an error returned when trying to as a server.
Hi @aaron.mcneil
It is a normal behavior. You cannot start a TCP Connection in Direct Data Flow (KTCPSTART) with only a server configuration.
You need a TCP connection between the client and the server to start a TCP Connection in Direct Data Flow (KTCPSTART).
Please help to tick “Solution” if your question is answered.
