I intend to build an autonomous device which is based on Q2686 cpu. After making my code and downloading it to the Q2686 chip, I would like the CPU to execute this application as soon as it is powered on (for example: after switching on the device, I would like it to continuously watch if a button is pushed and do something then).
For this application I am quite certain that I must base on telemetry sample (right?) but my wondering is the following: for achieving this, should I also use MultiApp library with its “start” and “stop application” commands? But this solution also demands to use AT commands which I think I don’t need for this kind of application.
Can anyone suggest me what to do? Because I am a little bit confused about which way should I use!
Thanks awneil for your quick response and consult!
So you think that if I make my code without using MultiApp and download it to Q2686 and type for the first time that I do this “AT+WOPEN=1”, then my application will always start automatically when the device is powered on?
But the problem is that I want to combine 2 functions in one application (eg watching when a button is pushed and do something and sending data continuously). Doeasn’t this require a multi thread environment which will use MultiApp library?
