I am encountering an issue similar to the one described in the forum thread. Additionally, I receive a notification, +KTCP_NOTIF: 2,4, before encountering the CME ERROR: 923. Occasionally, after hundreds of successful iterations, I suddenly see +KTCP_NOTIF: 2,4 and then CME ERROR: 923 in response to my KTCPSND command, which follows the +KTCP_NOTIF: 2,4. I expect to see “CONNECT,” after which I send the data and then terminate the session.
From my observations, the best solution seems to be deleting the session and starting a new one rather than attempting to recover it.
But before we discuss this, I have a couple of questions:
- Should we apply any delay between sending and receiving TCP data using AT commands? Please see in the log below time between at commands.
- Should we expect and process any notification / URC data after sending tcp data before sending the next data? or Should we expect to receive data first (run AT+KTCPRCV command) before sending the next data?
Please review these logs to see the sequence of AT commands I am using for TCP communication and where the CME error occurs. The logs include a comparison of successful TCP communications on the right versus failed communications on the left.
Thank you, kind regards.
Note that, I review the A.5 How to Use TCP Commands section in the document HL78xx AT Command Reference Guide rev 22 and couldnt see any information:
Module Im using is HL7812 with 5.5.8.0
