Hi All
Can any one explian us the significations of the values returned by AT+CSQ.
Hi All
Isn’t it explained in the AT Commands Manual?
Hi awneil;
Yes it’s explained in the manual but, not enough.
I mean that i don’t know what is the values that can be considered as good.
You should’ve made that clear in the original question, then! 8)
There is no simple answer to this - “your mileage may vary”, as the Americans say…
The Fastrack User Guide says
You should check the documentation for the particular product that you are using - performance may vary?
Also, SMS tends to cope with far lower levels than Data or Voice calls; I don’t know about GPRS.
