AT command to get info for WCDMA
Is there an AT command similar to AT!LTEINFO but for 3G? I want to get information like RSRP and bandwidth which I don’t see in AT!GSTATUS when I’m connected to WCDMA, unlike LTE.
here says you should use RSCP for 3G, so you should be able to see this in AT!LTEINFO:
If my 3G connection is super slow, does that mean the AT!LTEINFO won’t show up?
I can search on Google but can’t even run a speed test since it’s so slow. Is that why my AT!LTEINFO? says “Not Available”?
what are the response of the following?
ATI3
AT!IMPREF?
AT!GSTATUS?
AT!LTEINFO
at!gstatus?
!GSTATUS:
Current Time:  5598             Temperature: 32
Reset Counter: 38               Mode:        ONLINE
System mode:   WCDMA            PS state:    Attached
WCDMA band:    WCDMA 1900
WCDMA channel: 487
GMM (PS) state:REGISTERED       NORMAL SERVICE
MM (CS) state: IDLE             NORMAL SERVICE
WCDMA L1 state:L1M_PCH_SLEEP    LAC:         2D83 (11651)
RRC state:     CELL_DCH         UTRAN Cell ID: 06416263 (104948323)
Rx0 RSSI C0:   -82.2            Rx1 RSSI C0:  ---
Rx0 RSSI C1:    ---             Rx1 RSSI C1:  ---
at!lteinfo?
!LTEINFO: Not Available
ati3
Model: EM9293
Revision: SWIX65C_02.17.08.00 944ad5 jenkins 2024/08/01 20:22:05
IMEI: 355333960201313
IMEI SV:  5
FSN: EG4464896401B1
+GCAP: +CGSM,+DS,+ES
AT!IMPREF?
!IMPREF:
 preferred fw version:    02.17.08.00
 preferred carrier name:  ROGERS
 preferred config name:   ROGERS_030.033_001
 preferred subpri index:  000
 current fw version:      02.17.08.00
 current carrier name:    ROGERS
 current config name:     ROGERS_030.033_001
 current subpri index:    000
Is that you cannot use the RSSI value in AT!GSTATUS?
I’d prefer the RSRP/RSCP if possible
have you tried the MBPL \SampleApps\lite-qmi-nas?
I saw in the readme file, you can see it in
  7.4 Get Signal Info
  7.8 Get Cell Location Info
  7.10 Get TxRx Info Ext
Thanks, got the RSCP. Do you see anywhere if I can get the bandwidth?
does this help?
