AR7554: Legato Device Tools missing
as described on legato.io/legato-af/14_1/tools.html there should be SIM + APN + Data Commands, but on the AR7554 with the following firmware there is none:
Firmware Version: SWI9X15A_06.03.17.00 r23798 CNSHZ-AR-BUILD 2014/08/08 12:53:51
Bootloader Version: SWI9X15A_06.03.17.00 r23798 CNSHZ-AR-BUILD 2014/08/08 12:53:51
Linux Version: 3.4.36-yocto-standard #1 PREEMPT Fri Aug 8 07:16:46 EDT 2014
Missing:
legato.io/legato-af/14_1/sim … mands.html
legato.io/legato-af/14_1/dem … usage.html
legato.io/legato-af/14_1/data_commands.html
My assumption is that this is due to still under construction (early beta status) software.
Is there a newer firmware available for the AR7 board?
Br,
Martin…
Already received the information that the newer legato versions support it by the cm tool.
My legato version is 14.10.0.Beta
cm tool for radio, sim, data is already present and can be used.
