I am writing code using the airvantage APIs to manage SIMs. I don’t see anything that will move a SIM from ACTIVE back to INVENTORY.
I looked all over:
https://source.sierrawireless.com/airvantage/av/reference/cloud/API/API-System-v1/
there is nothing that will do this.
Also is there a way to change the ICCID of a system once its ACTIVE?
indeed you can’t move back a SIM from ACTIVE to INVENTORY. You can only suspend your SIM (pause the use of your SIM, you can ‘resume’ to Active to be able to use it again) or terminate (the sim can not be used anymore for ever).
The ICCID is an Identifier which is strongly related to the plastic sim: it can not be changed as well.
Regards.
