adl_fcmSendData to UART1 doesn't work with timers
I am using fcm UART1 and I want to send on UART1 periodically some data. I’ve inserted adl_fcmSendData(FCMHandler,“abc”,3); in timer handler, but it doesn’t work.
What’s wrong with this call in timer? Seems that it cannot work with fcm? How can I resolve this issue?
Code:
#include "adl_global.h"
/*  Mandatory variables                                                    */
/*  wm_apmCustomStackSize                                                  */
const u16 wm_apmCustomStackSize = 1024;
s8 FCMHandler;
bool FcmCtrlHandler (adl_fcmEvent_e Event)
    s8 s8r;
    TRACE (( 1, "Ctrl Event %d", Event));
    switch (Event)
        case ADL_FCM_RET_ERROR_GSM_GPRS_ALREADY_OPENNED :
         TRACE((1, "Flow GSM already Opened"));
         adl_atSendResponse ( ADL_AT_UNS, "ADL_FCM_EVENT_FLOW_OPENNED\n\r");
         break ;
   case ADL_RET_ERR_PARAM :
         TRACE((1, "Open Flow GPRS Parameters Error"));
         break ;
   case ADL_RET_ERR_ALREADY_SUBSCRIBED :
         TRACE((1, "Flow GPRS already subscribed"));
         break ;
   case ADL_FCM_EVENT_FLOW_OPENNED :
         TRACE((1, "ADL_FCM_EVENT_FLOW_OPENNED"));
         adl_atSendResponse(ADL_AT_UNS,"fcmSubscribe openned\r\n");
            adl_fcmSwitchV24State(FCMHandler,ADL_FCM_V24_STATE_DATA);
         TRACE(( 1, "adl_fcmSwitchV24State Ret= %d", s8r));
         break ;
   case ADL_FCM_EVENT_FLOW_CLOSED :
         TRACE((1, "ADL_FCM_EVENT_FLOW_CLOSED"));
         break ;
   case ADL_FCM_EVENT_RESUME :
         TRACE((1, "ADL_FCM_EVENT_RESUME"));
         break ;
   case ADL_FCM_EVENT_MEM_RELEASE :
         TRACE((1, "ADL_FCM_EVENT_MEM_RELEASE"));
         break ;
   case ADL_FCM_EVENT_V24_DATA_MODE:
         TRACE((1, "ADL_FCM_EVENT_V24_DATA_MODE"));
         adl_atSendResponse(ADL_AT_UNS,"now be data_mode\r\n");
         s8r=adl_fcmSendData(FCMHandler,"abc",3);
         TRACE(( 1, "adl_fcmSendData Ret= %d", s8r));
         break ;
   case ADL_FCM_EVENT_V24_AT_MODE:
         adl_atSendResponse(ADL_AT_UNS,"now be at_mode\r\n");
         break ;
   default :
         adl_atSendResponse(ADL_AT_UNS,"FCM_ControlHandler Event not processed\r\n");
         TRACE((1, "Embedded : FCM_ControlHandler Event not processed"));
         break ;
return TRUE;
bool FcmDataHandler (u16 DataLen, u8 * Data)
    TRACE (( 1, "Data Event %d", DataLen));
    char Buffer[150];
    sprintf(Buffer," %u : ",DataLen);
    adl_fcmSendData (FCMHandler,(u8*)&Buffer,(u16)strlen(Buffer));
    adl_fcmSendData (FCMHandler,Data,DataLen);
return TRUE;
void HelloWorld_TimerHandler ( u8 ID )
    TRACE (( 1, __TIME__ ));
    TRACE (( 1, "Value of ID: %d",ID ));
/*  Function   : adl_main                                                  */
/*  Object     : Customer application initialisation                       */
/*  Variable Name     |IN |OUT|GLB|  Utilisation                           */
/*  InitType          |   |   |   |  Application start mode reason         */
void adl_main ( adl_InitType_e  InitType )
    TRACE (( 1, "Embedded : Appli Init" ));
 if (adl_fcmIsAvailable(ADL_PORT_GSM_BASE)== TRUE)
        TRACE (( 1, "ADL_PORT_GSM_BASE READY TO HANDLE" ));
        adl_atSendResponse ( ADL_AT_UNS, "ADL_PORT_GSM_BASE READY TO HANDLE\32\r\n" );
 else
        TRACE (( 1, "NOT READY -> ADL_PORT_GSM_BASE" ));
        adl_atSendResponse ( ADL_AT_UNS, "NOT READY -> ADL_PORT_GSM_BASE\32\r\n" );
 if (adl_fcmIsAvailable(ADL_PORT_GPRS_BASE)== TRUE)
        TRACE (( 1, "ADL_PORT_GPRS_BASE READY TO HANDLE" ));
            adl_atSendResponse ( ADL_AT_UNS, "ADL_PORT_GPRS_BASE READY TO HANDLE\32\r\n" );
 else
        TRACE (( 1, "NOT READY -> ADL_PORT_GPRS_BASE" ));
            adl_atSendResponse ( ADL_AT_UNS, "NOT READY -> ADL_PORT_GPRS_BASE\32\r\n" );
 if (adl_fcmIsAvailable(ADL_PORT_UART1)== TRUE)
        TRACE (( 1, "ADL_PORT_UART1 READY TO HANDLE" ));
            adl_atSendResponse ( ADL_AT_UNS, "ADL_PORT_UART1 READY TO HANDLE\32\r\n" );
 else
        TRACE (( 1, "NOT READY -> ADL_PORT_UART1" ));
            adl_atSendResponse ( ADL_AT_UNS, "NOT READY -> ADL_PORT_UART1\32\r\n" );
 FCMHandler = adl_fcmSubscribe( ADL_PORT_UART1, FcmCtrlHandler , FcmDataHandler);
    /* Set cyclic timer */
    adl_tmrSubscribe ( TRUE, 60, ADL_TMR_TYPE_100MS, HelloWorld_TimerHandler );
In terminal I get:
Thanks in advance.
Tom
I propose you changing the text sent using “adl_atSendResponse”, on adl control handler. There are some events generating the same text. Be careful with the copy and paste.
Maybe you are already sending the data and the problem belongs to the UART configuration or something like that. Who are you triying to read the sent data?
