About InternetConnection
Hi, I’m trying to record the data from the SMS like this:
/* We get a -1. This means that there is some problem in the received SMS and actual
           error has been copied in the DataBuffer. We just need to send the response SMS to
           the number present in the phoneNum array */
        case BAD_PARAM_OR_CONFIG:
            adl_tmrSubscribe(FALSE,TimerValue,ADL_TMR_TYPE_100MS,SendRespSMS);
            bRet = FALSE;
            break;
        /* We get a 3. This means that the configuration SMS is correct and we need to use IP
           as the bearer for making the connection. */
        case USE_IP_BEARER:
        	adl_atSendResponse(ADL_AT_RSP,"Espacio en Flash:\r\n");
    		PrintCurrentAvailableMem();
    		/* Subscribe flash ID */
    		subscripcion = adl_flhSubscribe((ascii *)FlashHandle_1, MAX_OBJ_IDS);
    		TRACE((2,"Subscribe to flash = %d",subscripcion));
    		/* Get the count of IDs and print the same */
    		wm_sprintf(RspBuffer,"\r\nCurrent Count of Flash: %d\r\n", adl_flhGetIDCount((ascii *)FlashHandle_1));
    		/* Send the response */
    		adl_atSendResponsePort(ADL_AT_UNS,CurrentPort, RspBuffer);
        	/* Step 4: Print the current memory status */
        if (subscripcion== ADL_RET_ERR_ALREADY_SUBSCRIBED){
            TRACE((2,"Subscribe to flash = %d",sRet));
            adl_atSendResponse(ADL_AT_RSP,"OK, SUBSCRITO A FLAHS\r\n");
              IPLength = adl_flhExist((ascii *)FlashHandle_1, IP);
                //SI NO EXISTE EL OBJETO
                if (IPLength==OK){
                    wm_sprintf(IpAddr, "IP%d\r\n", IP);//LO ESCRIBO
                    escribirIp=adl_flhWrite((ascii *)FlashHandle_1, IP, wm_strlen(IpAddr)+1, (u8 *)IpAddr);
                    if(escribirIp==OK){//SI ESCRIBE BIEN
                        adl_atSendResponse(ADL_AT_RSP,"\nObjeto Escrito correctamente\r\n");
                        TRACE((3,"Write to flash,OBJ%d",IP));
                        TRACE((3,"El valor de la longitud del obj%d es:%d",IP,IPLength));
                        /* Print the current memory status */
                    else{//SI NO ESCRIBE BIEN
                        adl_atSendResponse(ADL_AT_RSP,"Objeto no escrito correctamente\r\n");
                        TRACE((3,"NO Write to flash, OK = %d",escribirIp));
                        if (sRet == ADL_RET_ERR_PARAM)
                            adl_atSendResponse ( ADL_AT_UNS, "\r\n Un parametro es erroneo\r\n");
                        else if (sRet == ADL_RET_ERR_UNKNOWN_HDL)
                            adl_atSendResponse ( ADL_AT_UNS, "\r\n Handle desconocida\r\n");
                        else if (sRet == ADL_FLH_RET_ERR_ID_OUT_OF_RANGE)
                            adl_atSendResponse ( ADL_AT_UNS, "\r\n Id fuera de rango\r\n");
                        else if (sRet == ADL_FLH_RET_ERR_OBJ_NOT_EXIST)
                            adl_atSendResponse ( ADL_AT_UNS, "\r\n El objeto no existe\r\n");
This to save the ip for example.
And then to read it to start the application running:
  /* Check if the SIM pin is available in the object area */
  if (subscripcion == ADL_RET_ERR_ALREADY_SUBSCRIBED)
    // LEER IP
    s32 ipLength=0;
    /* Check the length of the SIM PIN */
    ipLength = adl_flhExist((ascii *)FlashHandle_1, IP);
    if (ipLength > 0)
        /* Read from the flash */
        sRet=adl_flhRead((ascii *)FlashHandle_1, IP, ipLength,(u8 *) IpAddr);
        if (sRet == OK){
            adl_atSendResponse ( ADL_AT_UNS, "\r\n Ip leida correctamente\r\n");
            contador++;
            TRACE (( APP_MSG_TRACE_LEVEL, "Flash Write return value is: %d", subscripcion ));
        else {//SI NO LEE BIEN
            adl_atSendResponse(ADL_AT_RSP,"NO LEIDO objeto\r\n");
            TRACE((3,"NO read from flash = %d",sRet));
        //adl_simSubscribe(SimHandler, FlashPin);
    else
        adl_atSendResponse ( ADL_AT_UNS, "\r\n No hay IPS\r\n");
 // FIN LECTURA IP
For example to read the ip.
After reading all the data i start the ipbearer but I do not think that sends the data to the server. What I do wrong?
