Error on sending sms (again)
hi, i have a sample as follow
#include "adl_global.h"
const u16 wm_apmCustomStackSize = 1024;
s8 handle;
adl_tmr_t *timeid;
bool isInited;
bool smsHandler(ascii *smsTel, ascii* smsTimeLength, ascii* smsText) {
	ascii buffer[200];
	wm_sprintf(buffer, "receive message from %s", smsTel);
	TRACE((1,buffer));
	wm_sprintf(buffer, "time=%s", smsTimeLength);
	TRACE((1,buffer));
	wm_sprintf(buffer, "content=%s", smsText);
	TRACE((1,buffer));
	return TRUE;
void smsCtlHandler(u8 event, u16 nb) {
	switch (event) {
	case ADL_SMS_EVENT_SENDING_OK:
		TRACE((1,"sms sending ok"));
		break;
	case ADL_SMS_EVENT_SENDING_ERROR:
		TRACE((1,"sms sending error, code=%d",nb));
		break;
	case ADL_SMS_EVENT_SENDING_MR:
		TRACE((1,"sms sending ok, refer=%d ",nb));
		break;
void sendSmsDelay(u8 ID) {
	if (isInited) {
		handle = adl_smsSubscribe(smsHandler, smsCtlHandler, ADL_SMS_MODE_TEXT);
		TRACE((1,"subscribed code %d",handle));
		s8 ret = adl_smsSend(handle, "0948138008", "hi~hi~", ADL_SMS_MODE_TEXT);
		TRACE((1,"sending message is %d",ret));
		adl_tmrUnSubscribe(timeid, sendSmsDelay, ADL_TMR_TYPE_100MS);
	} else {
		adl_simState_e st = adl_simGetState();
		TRACE((1,"wait for full init, state %d",st));
void simHandler(u8 event) {
	switch (event) {
	case ADL_SIM_EVENT_PIN_OK:
		TRACE((1,"sim event pin ok"));
		break;
	case ADL_SIM_EVENT_REMOVED:
		TRACE((1,"sim event removed"));
		break;
	case ADL_SIM_EVENT_INSERTED:
		TRACE((1,"sim event inserted"));
		break;
	case ADL_SIM_EVENT_FULL_INIT:
		TRACE((1,"sim event full init"));
		isInited = TRUE;
		break;
	case ADL_SIM_EVENT_PIN_ERROR:
		TRACE((1,"event pin error"));
		break;
	case ADL_SIM_EVENT_PIN_NO_ATTEMPT:
		TRACE((1,"event pin no attempt"));
		break;
	case ADL_SIM_EVENT_PIN_WAIT:
		TRACE((1,"event pin wait"));
		break;
void adl_main(adl_InitType_e InitType) {
	TRACE (( 1, "project 10 sms : Main" ));
	isInited = FALSE;
	s32 ret = adl_simSubscribe(simHandler,NULL);
	TRACE((1,"Subscribed %d",ret));
	timeid = adl_tmrSubscribe(TRUE, 50, ADL_TMR_TYPE_100MS, sendSmsDelay);
when i start this sample, the simHandler did not receive ADL_SIM_EVENT_FULL_INIT event, adl_getSimState() function always return 0 (still init process, i think), if i call adl_smsSend() at this time, it return ADL_RET_ERR_BAD_STATE. the problem is that i wait for sim init procgress for long long time but simHandler still does not receive a ADL_SIM_EVENT_FULL_INIT.
  1. at this time, if i use AT+CMGS command to send sms, it send ok, so i think sim init progress must finished.
  2. but, if i remove the sim and insert back, this time simHandler receive ADL_SIM_EVENT_FULL_INIT event, and it work fine.
so i need remove & insert the sim everytime i run this sample , but where it was wrong? thanks.
Do a search on “ADL_SIM_EVENT_FULL_INIT” - this kind of thing has been discussed before.
In particular, when running in RTE (Remote) mode, early events are often missed.
You could also try subscribing WIND events…
thanks, in old topic i didn’t see this.
