Q24plus sms_send always returns ADL_RET_ERR_BAD_STATE
I don’t know how to solve this problem because it seems rather difficult
And I have red some posts related to this problem but i still haven’t got a solution
i checked the program and i found that when i send a SMS using adl_smsSend(),it always returns ADL_RET_ERR_BAD_STATE.
And my sim-card seems never finishes initing work. AT commands is ok.
Here is my code,can somebody do me a fovor?
#include "adl_global.h"
#include "wm_stdio.h"
u32 wm_apmCustomStack[512];
u16 wm_apmCustomStackSize=sizeof(wm_apmCustomStack);
s8 smsHandler;
s8 t;
s8 s;
bool smsHandle(ascii *Smstel,ascii *SmsTimeLength,ascii *SmsText)
    return TRUE;
void smsCtrlHandle(u8 Event,u16 Nb)
    switch(Event)
    case ADL_SMS_EVENT_SENDING_OK:
    case ADL_SMS_EVENT_SENDING_MR:
    adl_atSendResponse(ADL_AT_UNS,"SMS_EVENT_SENDING_OK");
    break;
    case ADL_SMS_EVENT_SENDING_ERROR:
    adl_atSendResponse(ADL_AT_UNS,"SMS_EVEMT_SENDING_ERROR");
    break;
void tmrHandle(u8 ID)
    adl_atSendResponse(ADL_AT_UNS,"beginsss\n");
    t=adl_smsSend(smsHandler,"13588460198","aaa",ADL_SMS_MODE_TEXT);
    switch(t)
        case ADL_RET_ERR_PARAM:
        adl_atSendResponse(ADL_AT_UNS,"PARAM\n");
        break;
        case ADL_RET_ERR_UNKNOWN_HDL:
        adl_atSendResponse(ADL_AT_UNS,"HDL\n");
        break;
        case ADL_RET_ERR_BAD_STATE:
        adl_atSendResponse(ADL_AT_UNS,"BADSTATE\n");
        break;
        default:
        adl_atSendResponse(ADL_AT_UNS,"OK\n");
        break;
    s=adl_simGetState();
    if(s==ADL_SIM_STATE_FULL_INIT)
        adl_atSendResponse(ADL_AT_UNS,"init\n");
void adl_main(adl_InitType_e InitType)
    smsHandler=adl_smsSubscribe(smsHandle,smsCtrlHandle,ADL_SMS_MODE_TEXT);
    adl_tmrSubscribe(TRUE,200,ADL_TMR_TYPE_100MS,tmrHandle);
Hiya,
  1. Cross posted to viewtopic.php?f=21&t=4226
  2. Please use the CODE button to format your code - it makes it a lot easier for everyone else to read…
  3. After a quick look over your code, it looks like you are not testing for the SIM to have finished initialization (and the modem to have registered to the network) before trying to send the SMS (i.e. checking the result of adl_simGetState() after attempting to send the sms using adl_smsSend()).
Try something like this (pseudo code):
Set up SMSHandler function
Set up SMS_Send_Function (i.e. calls adl_smsSend())
Set up pollCreg() function to wait for network registration after SIM has initialized
    if (registered)
        Send SMS
    else
        set timer and repoll at+creg?
Set up SIM_Handler_function:
    switch(SIM EVENT)
        case SIM_FULL_INIT:
            call pollCreg(0);
            break;
        default:
            break;
Set up initial_Timeout_Handler() (i.e. delay for a few seconds after application starts)
     adl_simState_e mySimState;
    mySimState = adl_simGetState();
                                        // need to wait for SIM to initialize
                                        // and subscribe to SIM handler
                                        // test if SIM required in simHandler
    adl_simSubscribe( gprs_simHandler, (ascii *)NULL);
    if( mySimState == ADL_SIM_EVENT_FULL_INIT  )    // SIM already OK, go straight to AT+CREG?
        pollCreg( 0 ); /* argument 0 is dummy, see poll_reg() "Object" comment */
    if ( mySimState == ADL_SIM_EVENT_PIN_WAIT )     // waiting for SIM PIN
        inputSimPin();
adl_main()
    set up one-shot timer to start rest of application.
To see exactly the steps required to check the SIM state and network registration, have a look at the WIP library samples - especially anything do to with GPRS setup as this process also has to wait for SIM init and network registration.
You’re close…
ciao, Dave
Thanks for your reply.I’ve tried using adl_simGetState,but it always returns ADL_SIM_STATE_PIN_OK
,and never changes.
The main problem is i don’t konw whether i need to finish the initing work with some function?
It seems like that when it runs the embedded program,it’s never switches to the ADL_SIM_STATE_FULL_INIT state.
Is there anybody who can help me,please?
Completetion of the initialisation is something you wait for - not something you do.
Are you running in Target or Remote mode?
I have known Remote mode to miss early SIM events…
IF you enable WIND indications, do you see the initialisation completing?
how long did you wait?
I’m probably don’t know the meaning of “wait”,when should i wait?
I found that everytime when i start the program,the sim initialization begins too.
So does that means i should use some delay function at the beginning of the program? If it does,how long should I wait for?
I don’t think i’m in RTE mode,I download the program into the module,then use AT+cfun=1,at+wopen=1 to run it
Now the module responses +wind 32767 when i use AT+wind? command,i don’t know if it means that i have enabled the WIND indication.
And i also changed some other values like creg,atq,atv as the ADL GUIDER.PDF says
I’m sorry maybe my statement is a little foolish,but i’m a rookie indeed
I wait for about 10 minutes(from resetting the module to running the program)
and i received those responses in Terminal Emulator after the resetting
+WIND: 3
+WIND: 13
+CGEV: ME CLASS “B”
+WIND: 1
+CREG: 2
+WIND: 7
+CREG: 1,“571E”,“4EDF”
+CREG: 1,“571E”,“28E4”
+WIND: 16
+WIND: 4
+WIND: 10,“SM”,1,“FD”,0,“ON”,0,“EN”,0
+WIND: 11,“96F4087EB258B336A176D466AA604736”,“CF60E71668025CEF094EEA964BED761B”,“EE412F523D74F35E05D886928F7783B5”
The last three responses come out quite slowly
