I am using Melody7.3 bluetooth stack.
I am configuring the used profiles using PROFILES config : max number of A2DP source connexion is set to 0 because my devise is used as sink only.
My problem is that when using SDPTOOL we can see that A2DP source was not declared as supported in ICS but advertised in SDP.
How can I disable A2DP source completely ? I don’t want the product to advertise A2DP source in SDP.
Please help,
Cheers,
Eric
Hi @er1c,
At the BC127’s perspective , when you set BC127 as sink it will display SNK in status as below. Note that, It requires a reset module
SET PROFILES=0 0 1 0 1 0 0 0 0 0 0 0
write
reset
BlueCreation Copyright 2017
Melody Audio V6.1.5
Build: 1496939390
Ready
open 482CA00A55AD aghfp
open 482CA00A55AD A2DP
status
STATE CONNECTED[1] CONNECTABLE[ON] DISCOVERABLE[OFF] BLE[OFF]
LINK 10 CONNECTED A2DP 482CA00A55AD SUSPENDED SBC SNK 48000
LINK 11 CONNECTED AVRCP 482CA00A55AD PAUSED
A2DP supports two roles—A2DP Sink (receiver) and A2DP Source (transmitter). Only one role may be enabled at any time. If A2DP sink is enabled so Source is disabled
Thanks for your answer.
I have the same configuration :
00:39 UART_TX VERSION
00:40 UART Sierra Wireless Copyright 2018
00:40 UART Melody Audio V7.3
00:40 UART Build: 1544637564
00:40 UART Bluetooth addresses: XXXX
00:40 UART Profiles: A2DP AVRCP HFP BLE TWS
00:40 UART Codecs: SBC AAC
00:40 UART OK
00:42 UART_TX STATUS
00:42 UART STATE CONNECTED[1] CONNECTABLE[ON] DISCOVERABLE[OFF] BLE[ADVERTISING]
00:42 UART LINK 10 CONNECTED A2DP 7C11CBC7FF20 SUSPENDED SBC SNK 44100
00:42 UART LINK 11 CONNECTED AVRCP 7C11CBC7FF20 STOPPED
00:43 UART LINK 13 CONNECTED HFP 7C11CBC7FF20 IDLE NB
00:43 UART OK
But even with SNK connection I can see A2DP SRC advertising. Please find below the SDPtool output :
Service RecHandle: 0x10000
Service Class ID List:
"Audio Sink" (0x110b)
Protocol Descriptor List:
"L2CAP" (0x0100)
PSM: 25
"AVDTP" (0x0019)
uint16: 0x0103
Profile Descriptor List:
"Advanced Audio" (0x110d)
Version: 0x0103
Service RecHandle: 0x10001
"Audio Source" (0x110a)
"L2CAP" (0x0100)
PSM: 25
"AVDTP" (0x0019)
uint16: 0x0103
Version: 0x0103
Service RecHandle: 0x10002
"AV Remote" (0x110e)
"AV Remote Controller" (0x110f)
"L2CAP" (0x0100)
PSM: 23
"AVCTP" (0x0017)
uint16: 0x0104
Version: 0x0106
Service RecHandle: 0x10003
"AV Remote Target" (0x110c)
"L2CAP" (0x0100)
PSM: 23
"AVCTP" (0x0017)
uint16: 0x0104
Version: 0x0106
Service Name: Hands-Free unit
Service RecHandle: 0x10004
"Handsfree" (0x111e)
"Generic Audio" (0x1203)
"L2CAP" (0x0100)
"RFCOMM" (0x0003)
Channel: 10
Language Base Attr List:
code_ISO639: 0x656e
encoding: 0x6a
base_offset: 0x100
Version: 0x0107
Service RecHandle: 0x10006
UUID 128: 00001002-d102-11e1-9b23-00025b00a5a5
Service RecHandle: 0x10007
"PnP Information" (0x1200)
Service Name: Headset
Service RecHandle: 0x10008
"Headset" (0x1108)
"" (0x1131)
"L2CAP" (0x0100)
"RFCOMM" (0x0003)
Channel: 13
code_ISO639: 0x656e
encoding: 0x6a
base_offset: 0x100
"Headset" (0x1108)
Version: 0x0102
It shows that even with one open A2DP SNK, the stack has not disable the A2DP SRC.
Please could you propose a patch which delete the A2DP SRC when stack is configured to be used as SNK ?
