nothing change still get same error as before.
I don’t see problem to download:
http://downloads.yoctoproject.org/releases/uninative/2.4/x86_64-nativesdk-libc.tar.bz2
i remember there is no need to enter those lines, maybe you add it, that is why it has error
but if I don’t add it still got error
this one
if this not the way to fixed then how can I do?
Strange that the version is SWI9X06Y_02.35.02.00, this is not for WP76 R16.0.1
I cannot found that where it have write version SWI9X06Y_02.35.02.00 ??
in your picture above:
I can make Yocto R16.0.1 but still cannot make yoctoR13.3.
Can I use ycotoR16.0.1 with WP7605 that install firmware R13.3 Docomo ??
Why suddenly you can build successfully?
BTW, why don’t you try R16.1 which has DOCOMO?
I believe this issue is centered around git version being used.
The issue does not appear in older version of ubuntu, I believe that is because an older version of git is the default version. For newer versions of git, the first error giveb is:
Exception: bb.process.ExecutionError: Execution of '/var/wp77xx/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/mdm9x28-image-minimal/1.0-r0.0/temp/run.do_generate_version_file.4567' failed with exit code 128
This is remediated with git config --global --add safe.directory '*' where the issue is replaced with:
Exception: bb.process.ExecutionError: Execution of '/var/wp77xx/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/mdm9x28-image-minimal/1.0-r0.0/temp/run.do_generate_version_file.1600' failed with exit code 1
Reading through the debug logs, the error seems to be:
+ determine_kernel_versions
+ cd /var/wp77xx/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/mdm9x28-image-minimal/1.0-r0.0/deploy-mdm9x28-image-minimal-image-complete
+ '[' '!' -e /var/wp77xx/yocto/build_bin/tmp/work/swi_mdm9x28_wp-poky-linux-gnueabi/mdm9x28-image-minimal/1.0-r0.0/deploy-mdm9x28-image-minimal-image-complete/mdm9x28-image-minimal-swi-mdm9x28-wp-20240322181619.rootfs.manifest ']'
+ echo 'Image manifest does not exist.'
+ exit 1
That file does exist so i am not 100% sure why it is not being detected. Will update this thread when i figure it out.
This issue is not seen when starting from a clean YoctoDistro (IE: untar the file) , running
git config --global --add safe.directory '*'bitbake linux-msmbitbake mdm9x28-image-minimal
This suggests that there is two issues to mdm9x28-image-minimal recipe:
- Having to perform
git config --global --add safe.directory '*' - Not cleaning up if an issue arises with
gitas this can only be fixed with a complete recreation of the yocto env. The cleanup task in the recipe likely needs to be updated.
