Hi @aleksander0m, thank you for pointing out the error. We’ll fix the links.
The exe files include the same FW binary files and you can extract them and use them on LInux. Thanks.
@aleksander0m, the links have been fixed. @fs1, the release note is r01.13 which is the correct one for R12 firmware. The different dates are a bit confusing.
@anon56110884 yeah, unpacking the exe files is also something I always do to make sure the md5 of the files are the same ones as the ones packaged in the zip files anyway…
Also, wanted to ask, the EM7511 firmware updates are also the same ones as for the EM7565, right? the md5 of the files matched in this case. If so, will the firmware updates always be the same for EM7511 and EM7565?
Hi @aleksander0m, EM75xx firmware can be used on either of the modems. However, you should only use the firmware that has been certified and approved for the respective modem. We strive to keep the carrier approved firmware versions between modems the same, but it is not always possible.
