[WP8548] Failed to build yocto
Hi
I don’t know if this is the right forum for this question. But I have a problem when I try to build yocto for the WP8548
my error is:
NOTE: Tasks Summary: Attempted 639 tasks of which 0 didn’t need to be rerun and 2 failed.
Summary: 2 tasks failed:
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff_git.bb:do_fetch
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag_git.bb:do_fetch
Does anyone have a solution? Thank you.
Best regards,
JeremyL
What FW release are you building?
What is the error message?
BTW is it same issue as this one?
Hi
I try to build the release 17
The error message is :
WARNING: time-genoff-git-r0 do_fetch: Failed to fetch URL file://time-genoff-bin.tar.bz2, attempting MIRRORS if available
ERROR: time-genoff-git-r0 do_fetch: Fetcher failure: Unable to find file file://time-genoff-bin.tar.bz2 anywhere. The paths that were searched were:
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/…/…/…/meta-swi-mdm9x28-bin/files/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff-git/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/files/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/…/…/…/meta-swi-mdm9x28-bin/files/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff-git/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/files/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/…/…/…/meta-swi-mdm9x28-bin/files/armv7a
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff-git/armv7a
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff/armv7a
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/files/armv7a
/home/devmangoh/Documents/SourceMangoh/build_bin/downloads
ERROR: time-genoff-git-r0 do_fetch: Fetcher failure for URL: ‘file://time-genoff-bin.tar.bz2’. Unable to fetch URL from any source.
ERROR: time-genoff-git-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/devmangoh/Documents/SourceMangoh/build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/time-genoff/git-r0/temp/log.do_fetch.17469
ERROR: Task (/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/time-genoff/time-genoff_git.bb:do_fetch) failed with exit code ‘1’
Followed by this error message:
WARNING: diag-git-r6 do_fetch: Failed to fetch URL file://diag-bin.tar.bz2, attempting MIRRORS if available
ERROR: diag-git-r6 do_fetch: Fetcher failure: Unable to find file file://diag-bin.tar.bz2 anywhere. The paths that were searched were:
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/…/…/…/meta-swi-mdm9x28-bin/files/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag-git/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/files/poky
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/…/…/…/meta-swi-mdm9x28-bin/files/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag-git/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/files/swi-mdm9x28
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/…/…/…/meta-swi-mdm9x28-bin/files/armv7a
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag-git/armv7a
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag/armv7a
/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/files/armv7a
ERROR: diag-git-r6 do_fetch: Fetcher failure for URL: ‘file://diag-bin.tar.bz2’. Unable to fetch URL from any source.
ERROR: diag-git-r6 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/devmangoh/Documents/SourceMangoh/build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/diag/git-r6/temp/log.do_fetch.17473
ERROR: Task (/home/devmangoh/Documents/SourceMangoh/meta-swi/…/meta-swi-extras/meta-swi-mdm9x28-bin/recipes/diag/diag_git.bb:do_fetch) failed with exit code ‘1’
log make image.txt (26.4 KB)
Best Regards,
JeremyL
Is it same issue as this one?
No it doesn’t seem to be the case
Didn’t it has same failure reason?
it has the same cause of failure but it seems that it is not the same case:
The cause of its problem seems to be that it did not enter the yocto directory before sending the make command.
In my case, I send the make command to the /home/Documents/sourceMangoh directory which is the directory where I made the repo command to download the source code from GitHub.
I am a beginner at Yocto so I don’t know if this is normal behavior but in my error:
Summary: 2 failed tasks:
The system is trying to retrieve time-genoff from meta-swi-mdm9x28-bin but I am using a WP8548, shouldn’t it be meta-swi-mdm9x15-bin instead?
Best regards
JeremyL
have you tried R16 before? Is it ok to build?
I’m having the same problem! The R16 does not work too. Did you find some solution?
I am facing the same issue, building just the base Yocto Image for WP7702:
(Linux Distro Source from the following webpage:)
source.sierrawireless.com/resources/airprime/software/wp77xx/wp77xx-firmware-latest-release-components/#sthash.V0INcb4y.zcZkxqwp.dpbs
@jyijyi same exact failure reason, maybe the protocol used to download the files is changed? But then why did it just fail for these two files, I am wondering.
Will be grateful for any help!!
just for testing, do you find problem to compile WP76 R16.0.1 yocto source?
No I didn’t try that. Since my device is WP7702, I tried the Linux Distro Source for wp77xx, which is R14.1 I believe
can you try that to get more clue?
OK sure let me try that. Thanks!
@jyijyi Is this the one you want me to try:
https://downloads.sierrawireless.com/_upload/wp76/Release16.0.1/v2/Legato-Dist-Source-mdm9x28-SWI9X07Y_02.37.10.02.tar.bz2
yes, you can try this
Hi @jyijyi I tried the above, and still getting the same issue:
Any ideas how to resolve this?
Thanks!!
Seems same issue as this one
Hi @jyijyi This issue there seems to be different (although the error is the same). Basically due to presence of $(PWD) instead of $(CURDIR) in Makefile, it is throwing the error when run make command from outside Yocto directory, but I am running make from inside Yocto directory. But still, I am trying this solution form the post to check if it works. Thanks for this! Will get back here with updates.
Hi @jyijyi I tried the solution (changed the makefile and replaced $(PWD) with $(CURDIR) at the sorresponding places mentioned in the sample Make file shared on the post comments). Still getting the same error (I expected that, since the issue in his case was due to path.
